Dustinsfl
- 2,235
- 5
One can show that mass diffusion without chemical reactions obeys the same basic equation as heat conduction.
The one dimensional equation in dimensionless variables is given by
D_{AB}\frac{\partial^2 C_A}{\partial x^2} = \frac{\partial C_A}{\partial t}
where [itex]C_A[/itex] is the concentration of the species [itex]A[/itex] diffusing into a medium [itex]B[/itex] and [itex]D_{AB}[/itex] is the mass diffusivity.
You should compare this to the analogous heat conduction problem.
As an example problem, consider of steel carburization.
In this high-temperature process carbon is diffused into the steel to achieve certain desirable material properties (e.g., increase tensile strength).
When the carburization is performed at a temperature [itex]1200^{\circ}[/itex]C the value of the diffusion coefficient is approximately [itex]D_{AB}\approx 5.6\times 10^{-10}[/itex] [itex](\text{m}^2/\text{sec})[/itex].
Suppose that a 1cm thick slab initially has a uniform carbon concentration of [itex]C_A = 0.2[/itex]%.
How much time is required to raise the carbon concentration at a depth of 1-mm below the slab surface to a value of 1%?
[Reminder: The transient solution requires homogeneous boundary conditions; the easiest way to achieve this is by rescaling/redefining the concentration variable.]
How do I find the time for when the value 1%
The boundary conditions are [itex]C_A(0,t) = C_A(1,t) = 0[/itex] and the initial condition is [itex]C_A(x,t) = .002[/itex].
We are looking for solutions of the form [itex]C_A(x,t) = \varphi(x)\psi(t)[/itex].
We have that
\begin{alignat}{3}
\varphi(x) & = & A\cos x\lambda + B\sin x\lambda
\end{alignat}
and
\psi(t) = C\exp\left[-D_{AB}\lambda^2 t\right].
The family of solutions for [itex]\varphi(x)[/itex] can be obtained by
\begin{alignat*}{3}
\varphi_1(0) = 1 & \quad & \varphi_2(0) = 0\\
\varphi_1'(0) = 0 & \quad & \varphi_2'(0) = 1
\end{alignat*}
This leads us to
\begin{alignat}{3}
\varphi(x) & = & A\cos x\lambda + B\frac{\sin x\lambda}{\lambda}.
\end{alignat}
Now, we can use the boundary conditions.
We have that
\varphi_n(x) = \sin x\lambda = 0,\quad \lambda = \pi n, \quad n\in\mathbb{Z}.
Our general solution is of the form
C_A(x,t) = \frac{1}{\pi}\sum_{n = 1}^{\infty}A_n\frac{\sin xn\pi}{n}\exp\left[-D_{AB}\lambda^2 t\right].
Finally, we can use the initial condition to solve for the Fourier coefficients.
A_n = \frac{.004}{n\pi}\int_0^1\sin xn\pi dx = \begin{cases}
0, & \text{if n is even}\\
.008, & \text{if n is odd}
\end{cases}
Therefore, the solution is
C_A(x,t) = \frac{.008}{\pi}\sum_{n = 1}^{\infty}\frac{\sin x(2n - 1)\pi}{2n - 1}\exp\left[-D_{AB}(2n - 1)^2\pi^2 t\right].
We have that
\begin{alignat}{3}
\end{alignat}
and
\begin{alignat*}{3}
\end{alignat*}
This leads us to
\begin{alignat}{3}
\end{alignat}
We have that
\end{cases}
