Mass flow rate
amitkaria2k
I have a Coriolis mass flow meter and I'm supposed to run water through it at different flow rates. I have a motor / pump which is controlled by AC drive (which is controlled by potentiometer). Also, I have a pressure transducer mounted at the input side of Coriolis mass flow meter
1. If I have to achieve a flow rate of X lb/min then at what speed (rpm) I should be running the motor / pump? Is there any equation that governs flow rate and motor / pump frequency?
2. Is there any equation that governs pressure at inlet of mass flow meter v/s the flow rate or motor / pump frequency?
NA
Answers and Replies
Chi Meson
1,807
No there is no such equation because all motors are different. I can't quite tell, but it seems that you are supposed to find out what the flow rate is for this pump by using the flow rate meter. What is the assignment, exactly, word for word?
RTW69
374
You will need to contact the pump manufacturer and get the pump curve for the pump you are using. It will show you the relationship between volumetric flow rate (gallons per minute) and head (feet). You can then use pump affinity laws to determine how flow capacity of your pump changes when pump speed changes.
Suggested for: Mass flow rate
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
45K
  • Last Post
9K
  • Last Post
