Homework Help: Mass flow rate
  1. May 9, 2013 #1
    Work out the mass flow rate of Nitrogen travelling through a at 0.3m^3/s if the pressure is 1 bar and the temperature is 18°C and the ideal gas constant is 8314 J/Kg K
    2. Relevant equations
    m=ρ*V*A
    m = mass flow rate
    ρ= density
    V = velocity
    A = flow area
    PV = nRT
    where
    P = pressure
    V = volume
    n = number of moles of gas
    R = gas constant
    T = absolute temperature
    3. The attempt at a solution
    I'm going round and round in a circle with it, the formula is simple enough and I know how to re-arrange it to get density but I need to work out the volume which is:
    V = nRT/P
    in order to do this I need to find the number of moles which is:
    mass of the gas/ molecular mass
    how do I work out the mass of the gas?
    and how do I work out the flow area when there isn't one provided?
    Thanks
  3. May 9, 2013 #2
    rock.freak667
    You are given the volumetric flow rate in m^3/s which is given by:
    Volumetric flow rate = velocity * flow area.
    Using this, you will not need the area
Have something to add?
Draft saved Draft deleted
