What is the estimated mass flow in relativistic jets from black holes?
  • Thread starter mcjosep
  • Tags
    Jets Mass
In summary, there is currently no known hypothetical amount of mass being launched out of the poles of relativistic jets from black holes. However, there are some formulas and numbers available that could be used to estimate the mass flow. One paper provides a Lorentz factor and total energy flow, while another paper provides the mass of each electron and the conversion rate to ergs. By combining this information, it is possible to calculate the number of electrons per second being launched out of the poles of relativistic jets from black holes.
mcjosep
35
I have done a little reading on relativistic jets coming out of black holes. No where could I find a hypothetical amount of mass getting launched out of the poles. I was looking for an "amount per second" estimate. I know that it probably differs depending on how large the BH is, I am just curious as to what the number could be.
Astronomy news on Phys.org
This paper derives some formulas from which the mass flow might be estimated:
http://arxiv.org/pdf/0909.2576.pdf
But they don't carry out any such calculations.
This paper provides some numbers for the Lorentz factor (=50) and the total energy flow (10^46 ergs/sec):
http://www.bu.edu/blazars/paperstodownload/marscher_michiganjets.pdf
So if you assume that everything is an electron, then the total energy of each electron is gamma*mc^2, where the electron mass is 0.511 MeV/c^2 for each one, times 50 for the total energy.
1 erg = 624,150 MeV/c^2 ... so now you can determine the total MeV flow per second, and divide by the amount per electron ... and you have electrons per second.
What is mass in relativistic jets?
Mass in relativistic jets refers to the amount of matter that is ejected from a compact object, such as a black hole or a neutron star, at extremely high speeds close to the speed of light. This mass is typically in the form of hot plasma and can range from a few solar masses to billions of solar masses.
How are relativistic jets formed?
Relativistic jets are formed through a process known as accretion, where matter falls onto a compact object and is accelerated by its intense gravitational field. As the matter gets closer to the compact object, it becomes heated and accelerated to high speeds, resulting in the formation of a jet.
What role does mass play in the formation of relativistic jets?
The mass of the compact object plays a crucial role in the formation of relativistic jets. The more massive the object, the stronger its gravitational pull, which can accelerate matter to higher speeds and result in more powerful jets. The composition of the matter also affects the formation and structure of the jets.
What is the significance of studying mass in relativistic jets?
Studying mass in relativistic jets can provide valuable insights into the behavior of matter in extreme environments, such as near black holes. It can also help scientists better understand the mechanisms behind the formation and dynamics of jets, which are important for the evolution of galaxies and the universe as a whole.
How do scientists measure the mass in relativistic jets?
Scientists use a variety of techniques to measure the mass in relativistic jets, including observing the jets at different wavelengths of light, analyzing the Doppler shifting of the emission lines, and studying the motion of the jets over time. These methods can provide valuable information about the mass and other properties of the jets.
  • Astronomy and Astrophysics
