Homework Help: Mass of a flywheel
  1. Apr 9, 2010 #1
    DR1
    a flywheel (A) with mass 100kg and radius of gyration 1200mm rotates at 150 rev min-1(clockwise). The kenetic energy of this flywheel it to be reduced by 20% by impacting with second flywheel (B) rotating at 80 revs min-1 (anti-clockwise), such that they have the same (clockwise) angular velocity after impact.
    Q1A) calculate the required mass of flywheel (B) if its radius of gyration is 800mm
    B) calculate the energy lost to the surroundings.
    C) Is the impact elastic? give reasons
    I have no idea were to start with this i found the moment of inertia for flywheel A but don't know if that will help 169kg m and thus found the kinetic energy of 20849.53 J and angular speed of 5pie rad s-1 im also sure the angular speed of flywheel B is 2.7pie rad s-1
    can anyone point me in the right direction please
  3. Apr 10, 2010 #2
    DR1
    does anybody have any ideas
  4. Apr 13, 2010 #3
    DR1
    Im guessing from the lack of response that this is not just me being stupid
    does anyone have any idea im sure someone is clever enough to help
  5. Apr 13, 2010 #4
    My problem is that I can't see how the collision is going to take place... CaN you be more specific?
    I guess your teacher's idea is to use conservation laws, for example, conservation of angular momentum.
  6. Apr 13, 2010 #5
    DR1
    im sorry i can not be any more specific all the info i have is in the question
    I have been studying a book as part of this assesment which covers conservation of energy so im sure that is the correct route to take.
  7. Apr 13, 2010 #6
    If energy conservation was all the story, they'd not be asking you whether the collision is elastic. In general terms, momentum and angular momentum conservation are far more important than energy conservation in applications. Even in non-elastic collisions they're conserved, while energy is not. Try the conservation of angular momentum, you will get an answer.
    My problem still is... how is the impact taking place? I mean, I don't know which geometry to imagine.
  8. Apr 13, 2010 #7
    DR1
    are you therfore implying that if i somehow use the formule
    Ia(W1)a + Ib (W1)b=Ia(W2)a + Ib(W2)b
    i will be able to start working this out my issue now is how do i use this effectively
    as far as impact taking place would it help to imagine it as a pair of clutch plates joining
    unfortunately the tutor is away at the moment hence the reason i am turning to you all for help
  9. Apr 13, 2010 #8
    Yes, this "clutch-type" collision sounds the most likely... And your formula sounds also nice, so why don't you just apply it? You know the two final angular speeds are equal...
  10. Apr 13, 2010 #9
    DR1
    the reason i am having an issue useing the formule is because im am not sure if the question implies the final angular speeds are equal at 150 rev min-1 or have changed due to the impact
    or am i over analyzing the question
  11. Apr 13, 2010 #10
    They want to reduce its kinetic energy, right? So you can find out the final angular velocity that we require.
  12. Apr 13, 2010 #11
    DR1
    ok so by reaaranging the formule as we know that the new KE after impact will be 20% less than before impact
    ke=.5IW^(2) FOR W
    i get the common angular volocity as being 14.04rads-1 does that sound about right or look correct
  13. Apr 13, 2010 #12
    Doesn't sound right to me. Too low. You reduce the kinetic energy by 20%, so do this:
    (a) Find the initial KE: (1/2) I w^2
    (b) Reduce that amount by 20%
    (c) Find the new w, corresponding to the reduced KE.
    Should be only a little bit lower than the initial 150 rpm
  14. Apr 13, 2010 #13
    DR1
    ok i think i mucked up my initial ke calculation
    redoing my figures takes the result down to 12.96rads-1 does that sound more like it
  15. Apr 13, 2010 #14
    sounds better to me too :) ok, you're in the right track!
  16. Apr 13, 2010 #15
    DR1
    ok fantastic so how would i get from that information to getting the mass of flywheel b
  17. Apr 13, 2010 #16
    Now, conservation of angular momentum.
  18. Apr 13, 2010 #17
    DR1
    without the moment of inertia for b the formule won't work or am i missing something
  19. Apr 13, 2010 #18
    In the equation for the conservation of angular momentum you have all but the moment of inertia for b, so you can get it...
  20. Apr 13, 2010 #19
    DR1
    just noticed that trying to work it out now
  21. Apr 13, 2010 #20
    DR1
    ok if i did it correctly i got an answer of Ib=86.27 but i not convinced my math is right
