Mass of a Photon
  • Thread starter Sothh
I know that a photon cannot have mass.
I know that a photon does carry energy, however.
So, just for fun I used E=mc2, to find out how much mass a photo would have.
This was mainly just to play around with the equation, but I found the answer interesting.
1.11265005605e-31 kilograms.
That is the mass of a single photon, even though I know its not.
What I don't know is why its not.
Answers and Replies
WannabeNewton
543
E = mc^2 is only valid for objects in their rest frames. A photon has no rest frame so that equation is invalid for a photon. A photon has momentum and this translates to a momentum density and momentum flux for a bunch of photons but that is not the same as rest mass.
Vanadium 50
Staff Emeritus
Education Advisor
27,661
11,884
You are using the wrong equation. E = mc2 is for a particle at rest, which a photon is not. For a particle in motion you need to use E2 = (pc)2 + (mc2)2. Since for light E = pc, if you will solve you will get m = 0.
Thanks!
I have always wondered about this.
If the photon transfers its energy to an object with a rest mass, then does it add mass to the object?
Pengwuino
Thanks!
There are two things you might be interested in. http://en.wikipedia.org/wiki/Compton_scattering" [Broken] occurs when a photon scatters off a particle and in turns, imparts some of it's energy to the particle and flies off with a smaller energy. However, the rest mass of the particle (What [itex]E=mc^2[/itex] really talks about) does not change; it simply gains kinetic energy.
There is also http://en.wikipedia.org/wiki/Pair_production" [Broken] where high energy photons can actually create massive particles.
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,977
4,683
Please start by reading the FAQ thread in the General Physics forum.
Zz.
edguy99
29
Thanks!
In Einstein's second paper on relativity in 1905, he explicitly concludes:
"Radiation carries inertia between emitting and absorbing bodies". It is important that not only does something receive a "kick" from the momentum of the energy, but the internal inertia (i.e., the inertial mass) of the body is actually increased. (from mathpages.com)
Among all this confusion, first [tex]E=Mc^2[/tex] is only good an an outdated concept of particles at rest - you need the relativistic formula [tex]E^2=M^2c^4+p^2c^2[/tex], but when I read your opening posts that photons cannot have a mass is simply wrong.
It does have a lower bound of mass at [tex]10^{-51}[/tex] g that is if one wants to believe it even has a mass of the ridiculously small length.
edguy99
29
I fully agree that the photon has no mass. But, one way to "weigh" this photon is to consider a box of mirrors mounted on a scale facing each other. Assume the "weight" of the mirrors on the scale is 1 kilogram. Say a photon goes by and does not get trapped by the mirrors. The scale will continue to be say exactly 1 kilogram.
Now, say the photon gets trapped by the mirrors and bounces back and forth between them. The scale will change and show a "weight" of slightly more then 1 kilogram (specifically, the mass equivalent of the photons energy).
In this way, you can view matter as trapped energy, it may be a vortex, mirrors, black holes or who knows what.
HallsofIvy
41,847
966
It does have a lower bound of mass at [tex]10^{-51}[/tex] kg that is if one wants to believe it even has a mass of the ridiculously small length.
Where did you get that figure?
I hope i said it in grams, but basically this is old-ish news:
http://aip.org/pnu/2003/split/625-2.html [Broken]
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,977
4,683
That's not a "lower bound mass". That's the UPPER limit of the mass, meaning that the photon mass, IF it exist, has to be lower than that.
Zz.
Related Threads on Mass of a Photon
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
