Find the Mass of Water that Freezes: Entropy Change Calculations
In summary, by mixing 32 g of water at 10°C with 430 g of ice at -5°C, the resulting system will have an energy change of -1340.8 J. In order to balance the energy equation, 9.4 grams of water will freeze. The change in entropy of the system cannot be determined without knowing the temperature of the surroundings.
loosely
1. At 10°C, 32 g of water is mixed with 430 g of ice at -5°C. (The heat capacity of water is 4190 J/(kg * °C), that of ice is 2090 J/ (kg *°C), and the heat of fusion of water is 3.34 * 10^5 J/kg)
a) What mass of water freezes ?
b) What is the change in entropy of the system?
What I did on part (a)
ice : -5°C -> 0°C
Q = m_ice C_ice delta T
Q = (0.43 kg) (2090 J/ (kg *°C) ) (0°C-(-5°C))
Q = + 4493.5 J
water: 10°C -> 0°C
Q = m_water C_water delta T
Q = (0.032 kg) (4190 J/ (kg *°C) ) (0°C-(10°C))
Q = - 1340.8 J
Qice + Qwater = 0
but it doesn't equal to zero.
Not sure what to do next.
Qice + Qwater + Qleftover = 0
Qleftover = m_Water Lf
m_Water = Qleftover / Lf
= 3152.7 J / (3.34 * 10 ^5 J/kg)
=0.00 9439 kg which is approximately 9.4 grams
Doesn't worked out to be the answer of 11 grams.
Where did I gone wrong?
Your help is appreciated.
Thanks.
The heat of fusion of water is 3.34*10^3 kJ/kg.
typo error. 3.34 *10^5 J/kg or 334 * 10^3 J/kg
I corrected the above typo error on the 1st post.
Your result, 9.4 grams, looks okay to me. Could be an error in the answer key.
Your calculations are correct, but there are a few things to consider. First, when you are calculating the heat absorbed by the ice, you need to take into account the fact that it is undergoing a phase change from solid to liquid. So the equation should be Q = m_ice * Lf + m_ice * C_ice * delta T. This takes into account the heat required for the phase change as well as the change in temperature.
Second, when you are calculating the heat released by the water, you need to use the negative value for the heat of fusion (since it is being released). So the equation should be Q = -m_water * Lf + m_water * C_water * delta T.
When you plug in the correct values, you should get a mass of water of approximately 11 grams, which is the answer given in the question. So it seems that you made a small calculation error somewhere. Double check your calculations and make sure you are using the correct signs for the heat of fusion and the heat released by the water.
What is the purpose of calculating the mass of water that freezes?
The purpose of calculating the mass of water that freezes is to determine the amount of energy required to change water from a liquid state to a solid state. This information is important in understanding the thermodynamic properties of water and how it behaves under different conditions.
How is the mass of water that freezes calculated?
The mass of water that freezes can be calculated by using the formula m = Q/ΔH, where m is the mass, Q is the heat energy released during freezing, and ΔH is the enthalpy of fusion of water.
What is the enthalpy of fusion of water?
The enthalpy of fusion of water is the amount of energy required to change one gram of water from a liquid state to a solid state at its melting point. It is a physical property of water and has a value of 334 J/g at 0°C.
How is the change in entropy calculated during water freezing?
The change in entropy during water freezing can be calculated by using the formula ΔS = Q/T, where ΔS is the change in entropy, Q is the heat energy released during freezing, and T is the temperature at which freezing occurs.
Why is understanding entropy change during water freezing important?
Understanding entropy change during water freezing is important because it helps us understand the spontaneity of the process and how energy is transferred and distributed. It also has practical applications in industries such as refrigeration and food preservation.
