• Support PF! Buy your school textbooks, materials and every day products Here!
Mass on a spring
  • Thread starter Akibarika
a steel spring that it extends by 10cm in equilibrium when you attach the upper end of the spring to a fixed support and hang a weight of 100g at the lower end.
And I found k and T, so how about if I change the weight to 1kg at the lower end and do the same thing?
F = -kx
I found they actually same.
when 100g
mg=kx
k=9.81
T=2pi*sqrt(m/k) = 2*pi*sqrt(0.1/9.81) = ...
when 1kg
mg=kx
k = 98.1
T=2pi*sqrt(m/k) = 2*pi*sqrt(1/98.1) = ...
same!?
I think I did wrong, who can help me?
THANK YOU!
Answers and Replies
Doc Al
Mentor
44,870
1,119
Why do you think the spring constant changes? If you are using the same spring, then you'll have the same spring constant. (You cannot assume that the spring extends by the same amount with a heavier weight hanging from it. If you do, then of course you'll get the same answer since m/k will be the same.)
Related Threads for: Mass on a spring
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
