Homework Help: Mass on elastic rope
  1. Dec 17, 2015 #1
    1. The problem statement, all variables and given data
    A mass hangs in balance on a elastic rope (k= 800 N/m). The lenght of the rope in balance is 1m. They pull the mass 25 cm out of balance. The mass colides with the ceiling (restitution coefficient = 0,8). How far extend the rope after the collision. ( Solution: 0,0113m)
    2. Relevant equations
    In balance: m*g=k*u
    Ek=1/2 m v2
    Ep= m*g*h
    Ev= 1/2 k u2
    3. The attempt at a solution
    I have tried different things with using the law of conversation of energy. But I think a have not enough known date. So, I compared the energy of the moment when the mass is pulled 25cm out of balance with the moment it collides with the ceiling:
    1/2 k (u+0,25)2=1/2 m v2+ m g 1,25
    I want to determine the speed. Then I know that the speed after the collision is equal to 0,8v. Then I would use the law of conversation of energy again to determine the extending of the rope. TO determine v I think have not enough data but maybe I forgot something. Can anyone help me? Thanks a lot!
  3. Dec 17, 2015 #2
    PeroK
    You seem to have the right idea: it's all about energy. Energy is always a combination of PE in the rope, gravitational PE and KE. Just keep going with your idea.
  4. Dec 17, 2015 #3
    PeroK
    Do you know the mass?
  5. Dec 17, 2015 #4
    No the mass is not given. Otherwise it would be so easy. :-(
  6. Dec 17, 2015 #5
    PeroK
    Mass is definitely a factor. You could solve the problem for two different masses to show this.
    The only other possibility is that the rope has 0 length when unweighted. That would allow you calculate the mass.
  7. Dec 17, 2015 #6
    Oke I'll try this tomorrow. Hopefully I find the right answer.
  8. Dec 17, 2015 #7
    PeroK
    The second idea can't work, because then the mass wouldn't hit the ceiling.
    You could solve it if you knew the unstretched length of the rope. Either that or the mass is required.
Have something to add?
Draft saved Draft deleted
