Understanding Mass Quantization in Elementary Particles
In summary, elementary particles have been found to have discrete rest masses, which could potentially be attributed to quantization of mass, as evidenced by the existence of a simple spin quantized mass formula and evidence of quantized unstable quark composite particle masses.
neelakash
511
Mass Quantization!
Elementary particles seem to have a discrete set of rest masses.Can this be regarded as quantization of mass?
No,the rest masses are not found to be integral multiple of some fundamental mass unit.
Please check my answer.
Re:Mass Quantization!
neelakash said:
Actually there is a rather simple spin quantized mass formula (relationship between) for the spin 1/2 electron, the spin 1/2 proton and the spin 1 W particles (if you ignore the SM view of mass).
Given the proton mass (M_p) and electron mass (M_e), take the mass value symmetrically between the proton and electron (M_s=sqrt(M_p*M_e)) and the mass distance (ratio) between the proton and electron (M_d=M_p/M_e). Denoting S as the spin quantum number (1/2, 1), C is the charge quantum number (+1, -1), and M is the matter quantum number (matter=+1 anti-matter=-1), then one has a single mass formula for the masses of the electron, proton and W particles ( M_(e,p,W) ) and their anti-particles given by
M_(e,p,W) = (2 S M_d)^(S C M) * M_s
This formula indicates that the masses of the fundamental particles are indeed quantized.
There is also evidence that unstable quark composite particle masses are also quantized. See "www.particlez.org"[/URL]
[quote="neelakash, post: 1514441"][h2]Homework Statement [/h2]
Elementary particles seem to have a discrete set of rest masses. Can this be regarded as quantization of mass?
[/QUOTE]
Quantization is one possible solution. Like stable orbital energy states (INTER-particle quantization?), quantization could result in stable particle energy states (INTRA-particle quantization?).
1. What does it mean when someone says "Yes, your answer is correct."?
It means that the answer you provided is accurate and in line with what is considered to be the correct or expected response.
2. How do I know if my answer is correct?
You can determine the correctness of your answer by comparing it to a known or accepted answer, or by receiving confirmation from someone with expertise in the subject matter.
3. Can there be more than one correct answer?
Yes, in some cases there can be multiple correct answers for a question. This is especially true in subjective or opinion-based questions.
4. Is "Yes, your answer is correct." always a definitive statement?
No, in some cases it may be used as a polite or encouraging response, without necessarily confirming the absolute correctness of the answer.
5. Is it important to have the "correct" answer in science?
In science, the pursuit of accuracy and correctness is crucial for advancing knowledge and understanding. However, it is also important to acknowledge that new discoveries and advancements can lead to changes in what is considered to be the "correct" answer.
  • Quantum Interpretations and Foundations
