Homework Help: Mass Spring Damping Question
  1. May 7, 2014 #1
    Suppose a mass- spring is modeled by x''+ cx'+100x. What should the damping constant c be in order that critical damping occurs?
    2. Relevant equations
    3. The attempt at a solution
    I set the discriminant equal to zero so that there are real repeated roots.
    B^2-4ac=0
    c^2=400.
    c=20 or c=-20.
    The answer should only be c=20. For critical damping, the constant must be positive?
  3. May 7, 2014 #2
    pasmith
    What is the repeated root? You need it to be negative so that [itex]x[/itex] decays with time, do you not?
  4. May 7, 2014 #3
    AlephZero
    For any level of damping, c must be positive.
    If c is negative, you are putting energy into the system, not taking energy out.
  5. May 7, 2014 #4
    ChrisVer
  6. May 7, 2014 #5
    BvU
    2017 Award
    An other way to look at it: damping force must be opposite to x', which it is if c is positive:
    x'' = -cx' -100x
Have something to add?
Draft saved Draft deleted
