Mass Spring System: Solving for Motion Over Time
In summary, the conversation discusses the equation for describing the motion of a mass hanging from a spring with a spring constant of 250 N/m and an amplitude of 12cm. The equation is x = 0.12cos(25.65t - 1.38) and the value of phi is determined to be 1.891 radians. The conversation also touches on the concepts of Hooke's Law and the restoring force in a simple harmonic motion.
frozen7
163
In a vertical mass spring system, spring with spring constant 250 N/m vibrates with an amplitude of 12cm when 0.38kg hangs from it.
What is the equation describing this motion as a function of time? ( assume the mass passes through the equilibrium point, towards the positive x(upward), at t = 0.110s)
I do it in this way:
Hooke`s Law: F = kx
(0.38)(9.8)= 250 N/m (x)
x = 0.015(m)
[tex]\omega[/tex] = [tex]\sqrt{k/m}[/tex]
[tex]\omega[/tex] = 25.65
x = Acos([tex]\omega[/tex]t + [tex]\phi[/tex])
0.015 = 0.12cos(25.65t + [tex]\phi[/tex])
[tex]\phi[/tex] = -1.38
So, the equation : x = 0.12cos(25.65t -1.38)
Is it correct?
1. Here the force is not mg, Actually mg is balanced by initial streach of the spring when it come in equilibrium position after the mass is attached.
2. F represents the restoring force trying to bring the mass back in the equilibrium position.
The spring extent because of mg. Then why not F = mg?
How should I find the phi?
What is the resultant force when the syatem is in equilibrium?
Actually the force F in S.H.M. is the restoring force on the mass when it has displacement x from equilibrium position.
your equation
[tex] x = A cos (\omega t + \phi ) [/tex]
is correct.
When x = 0 ; t = 0.110s
put these values to get [tex] \phi [/tex]
Ya, I did it in this way before also but the value I get is [tex]\phi[/tex] equal to -1.25
But it is actually should be about +1.89 ( from given answer)
[tex] cos \theta = cos \alpha [/tex] has general solution
[tex] 2n \pi \pm \alpha [/tex]
which sign is to be taken?
where was the mass at t = 0 ?
when t = 0
x = A
Any more clues?
The same solution can be written as 3pi/2 - wt = 4.712 - 2.821 = 1.891 this is given in your textbook.
The solutions of the equation are
[tex] \pi /2 - 2.821[/tex] and [tex] 3 \pi /2 - 2.821 [/tex]
= -1.25 and 1.891 radians respectively.
Now think, when t=0.11s; x=0 means at t = 0 the particle is yet to reach the equilibrium position [Where the phase angle (wt + phi) is pi/2] and x is - ve because the time period is 0.225s and 0.11s this is a bit less then half time period. For that the phase angle should be more then pi which is given by the value of phi = 1.891.
OK...Thanks...:)
1. What is a mass spring system?
A mass spring system is a physical system that consists of a mass attached to a spring. The mass is free to move along a straight line, while the spring provides a restoring force that brings the mass back to its equilibrium position when it is displaced.
2. How is the motion of a mass spring system over time calculated?
The motion of a mass spring system over time can be calculated using the equation: x(t) = A cos(ωt + φ), where x is the displacement of the mass from its equilibrium position, A is the amplitude of the motion, ω is the angular frequency, and φ is the phase angle.
3. What factors affect the motion of a mass spring system?
The motion of a mass spring system is affected by several factors, including the mass of the object, the stiffness of the spring, the amplitude of the motion, and the initial conditions (such as the initial displacement and velocity).
4. How does changing the mass or stiffness of the spring affect the motion of a mass spring system?
Changing the mass or stiffness of the spring can affect the motion of a mass spring system in different ways. Increasing the mass will result in a longer period of oscillation, while increasing the stiffness of the spring will result in a shorter period. Additionally, changing the mass or stiffness can also affect the amplitude and frequency of the oscillations.
5. Can a mass spring system have multiple modes of motion?
Yes, a mass spring system can have multiple modes of motion. This means that it can oscillate with different amplitudes and frequencies simultaneously, resulting in a complex motion pattern. The different modes of motion are determined by the system's natural frequencies, which depend on the mass and stiffness of the system.
