Weightless in Free Fall: Understanding the Physics Behind a Massless State
In summary: F=w(W is the upward force ,we call it Weight)when you having another force that pulling or pushing like in the elevator F+w=ma or w-F=ma when free falling,there are only the gravity force acting .F=ma in this case there have no W in the equation ... it seem to be weightless
doey
27
we are in weightless condition because there are no resultant force between Earth and me,at this instant, Earth and me are in the opposite direction moving toward each other,will Earth oso can consider weightless? when i free falling
p/s : beg pardon at 1st typing massless ,typing error ==
Your question hardly makes any sense. Is this a question at all?
The word "weightless" can be problematic since "weight" can have different meanings. The two most-used definitions of "weight" are:
1. The force exerted by gravity on an object. If we use this definition, we cannot say that an object near the Earth in free fall is weightless: gravity is still exerting a force on the object. in this case you might say that the apparent weight of the object in free fall is zero.
2. ("operational definition") The force measured by weighing the object with a force-sensitive scale. When this definition is used, an object in free fall is indeed "weightless".
How do you define the weight of the Earth? If you decide that it's the force exerted by the Earth's gravity on the Earth itself, then the answer is that the Earth's weight is always zero. Since the Earth is orbiting the Sun, you might prefer to define the Earth's weight as "the force exerted on it by the Sun", which you can calculate using Newton's law of gravitation.
Your post is confusing and hard to understand, as it contains a great many typing and grammar errors. It would help if you could spend a little more time making sure your post is clear, understandable, and concise.
sry for all that my posted consisting unclear and make all confuse.I knew I was mistaken the concept ==
is it means we are just weightless because of we cannot weight it in scale?I was confounded.it just stated when an object is in free fall,it is pulling by gravity ,it cannot be weightless.then how come it become weightless indeed as you told in number 2(above)
as i know ,it might be apparently weightless because there is no FORCE pushing or pulling it except gravity,just like when I 'm in universe(space) ,i will having the same feeling as i free falling.but different is in universe,i 'm at rest.Gravity is a field or a force actually?,i seem to confused now...or what i was thinking are totally wrong?
weight is really only relevant if we are in contact with something (eg the floor) …
we cannot feel our weight, we can only feel reaction forces between us and other objects
we only "feel" our weight when eg the floor pushes on us with a force whose magnitude (but not direction) we call our weight
if the floor is accelerating up (eg the floor of a rocket), then the reaction force is greater, so we feel heavier
but in free fall, there is no contact, so nothing to feel :wink:
ya,i was thinking this a whole night time==
here i come out an answer:
just like a person stand still on the floor,he has weight because the floor acting an upward force which respond toward the gravity.
F+w=ma or w-F=ma
F=ma
here i have a question,is the free falling acceleration not relate to our weight?if it is relate to our weight ,then the acceleration will only applicable when Free fall is happening on the surface of earth.
f=GMm assume an mass (m) is 1kg
r^2
the r is radius of earth,we can get the f is 9,81 then using F=ma to calculate the free fall acceleration.that means all our calculation relate to weight are only applicable when the object is on the surface of earth,right? W=m(9.81) ,if it is not on surface of earth,the 9.81 shouldn't be the gravitational acceleration because different radius is using now.
am i correct?
and as my inference,you can really feel if you are free falling,what about the tidal stress?despite i knew that there will be vry vry small and need not to be noticed
It's important to keep in mind that first definition only makes sense in Newtonian Gravity. So while it seems like it's a good definition for "true weight", ti becomes completely meaningless when you go to General Relativity. When you treat gravity as an artifact of space-time curvature, you find that second definition is the only one that makes sense. And in that context, a free-falling object is truly weightless.
hi doey! :smile:
r^2
yes, if we're in space, the acceleration is less than 9.81 …
at radius R, it's 9.81 r2/R2, where r is the Earth's radius
(actually, even on Earth, at sea level, g varies slightly, eg because of the varying thickness of the continental crust)
yes, that's right :smile:
it will be miniscule, but yes there's a slight stretching! :biggrin:
now you've got the hang of it, i'll say something that i didn't want to say earlier, in case it was confusing …
by "weight", we usually mean the gravitational force (from the Earth), mg, and we even call it "W"
but that isn't what is meant by "weight" or "weightless" in ordinary English …
in ordinary English (and in some exam questions :rolleyes:), it refers to the reaction force, N, that we feel from the floor etc, not the gravitational force!​
On any diagram of forces you would usuall find a downwards arrow, labelled 'W', whether on a table or in free fall. On a table, the force 'N' would be equal and opposite to W and it would be only then that you would be able to measure the Weight force.
I don't think that your 'weight' is ever anything other than your Effective Weight, including all the extra small forces on top of Earth's gravity. It's not a quantity that's of great interest in Science, compared with Mass.
What is massless in free fall?
Massless in free fall refers to an object that has no mass and is falling towards the ground under the influence of gravity.
Can an object truly be massless in free fall?
No, according to the laws of physics, all objects have some mass. However, in some cases, the mass of an object may be so small that it is considered negligible and can be treated as massless.
How is massless in free fall different from zero gravity?
Massless in free fall and zero gravity are two different concepts. Zero gravity refers to the absence of gravity, such as in outer space, while massless in free fall describes an object falling under the influence of gravity.
Does massless in free fall experience any forces?
Yes, even though the object has no mass, it still experiences the force of gravity. This is because the force of gravity is not dependent on an object's mass.
What is the significance of studying massless in free fall?
Studying massless in free fall can help us better understand the laws of gravity and the behavior of objects in free fall. It also has practical applications in fields such as physics, engineering, and space exploration.
  • Mechanics
  • Mechanics
