How Fast is the Area Changing in an Equilateral Triangle?
  • Thread starter Peppy
  • Tags
    Change
In summary, the area of an equilateral triangle can be expressed as A= (1/2)bh, where b is the base and h is the height. By using the Pythagorean theorem to relate b and h, we can write A as a function of h only. Differentiating this equation with respect to time gives us a relation between the rate of change of area, dA/dt, and the rate of change of height, dh/dt.
Peppy
I need help with the question: The heighth of an equilateral triangle is increasing at a rate of 3cm/min. How fast is the area changing when h is 5cm?
The area of a triangle is A= 1/2*bh
You know dh/dt = 3cm/min
Try manipulating the above equations to an appropriate form where you can find the area as a function of height, and inhernetly its rate of change.
Write the equation, which whozum gave you, A= (1/2)bh, Use a relation between b and h that is true for all equilateral triangles (divide the triangle into two right triangles and use the Pythagorean theorem) to write A as a function of h only.
Finally, differentiate with respect to t to get a relation between dA/dt and dh/dt.
1. What is the definition of "rate of change" in Math 31?
The rate of change in Math 31 refers to the measure of how one quantity changes in relation to another quantity. It is often expressed as the slope of a line on a graph and can be calculated using the formula (change in y / change in x).
2. How is the concept of "rate of change" applied in real-life situations?
In real-life situations, the concept of rate of change is used to analyze and understand various phenomena such as population growth, speed of a moving object, and the rate at which a chemical reaction occurs. It is also commonly used in business and economics to determine trends and make predictions.
3. What is the difference between average rate of change and instantaneous rate of change?
The average rate of change is calculated by dividing the change in the dependent variable by the change in the independent variable over a specified time interval. On the other hand, the instantaneous rate of change is calculated by taking the limit as the time interval approaches zero. In other words, it is the rate of change at a specific point in time.
4. How is the concept of "rate of change" related to derivatives?
The concept of rate of change is closely related to derivatives in calculus. The derivative of a function represents its instantaneous rate of change at any given point. This means that the derivative can be used to calculate the rate of change of a function at a specific point, just like the instantaneous rate of change.
5. What are some common applications of rates of change in calculus?
Some common applications of rates of change in calculus include optimization problems, related rates problems, and curve sketching. Rates of change are also used to solve problems in physics, engineering, and other fields that involve analyzing and predicting changes in variables over time.
  • General Math
