Calculating Excavated Tar Sands in One Hour: Math Exam Review Question
  • Thread starter Mozart
  • Tags
    Exam
In summary, Fred is having trouble with some questions from a math review package and is requesting help. The question is: how many kilograms of tar sands are excavated in one hour? Fred calculates that 1800000 kg are excavated in one hour.
Mozart
106
My final math exam is tomorrow, and I am having trouble with some questions as I go through this review package.
I have the answers so its very frustrating to arrive at the wrong answer over, and over.
Anyways the question is:
The position of a bucket on a circular tar sands excavator is given by the equation: p(t)= 10sin(6pit + 3pi) + 20
Where t is the time in minutes. There are 20 buckets on the excavator and each holds 500 kg
How many kilograms of tar sands are excavated in one hour?
The answer is 1800000 kg
This is what I did: p(t)=10sin(6pi(60)+3pi) + 20
P(t)= 28.69
from here I am lost so I just did 500 x 20= 10000
10000 x 28.69= 286900 kg
Can someone please help me? Thanks
How many times have did one excavator come to its starting place? How many times have did 20 excavators come to its starting place? can you answer these questions?
Are you to a calculus level yet? Can you take the derivative of the function you stated? The derivative of position is velocity...angular velocity in this case.
Well I think the period is .0055555556. I assume its that since I am using 6pi(60) as b. So 2pi/b gives me .0055555... When I plug in 60 minutes into the equation I get like 28.69. So I divided 28.69 by the period and got 5164.199959. Then I multiplied 5164.2 by 20 since there is 20 other buckets, and got 103284. I then multiplied this by 500 kg and got 51651999.6 kg.
Sorry Fred I havn't been exposed to any sort of calculus yet.
Think of the equation this way. The constant c does not change anything actually so we need not pay any heed to it, right? That's because we are interested in the period of this function. now take [itex]sin(6\pi*x+3\pi)[/itex] like this [itex]sin(a+b)[/itex]
Can you conclude anything about the function from here? The given function is actually equal to [itex]-10sin(6\pix)[/itex]. What can you do now?
Fred, I don't understand, what does this quesation have to do with the derivatives? We do not need to find the velocity. Or am I missing something?
It seems I cannot edit my posts for some unknown reason. Anyway the last latexed equation should be
[tex]-10sin(6\pi*x)[/tex]
I am really confused now. I don't know how you went from sin(6pix+3pi) to
-10sin(6pix). It seems I can't even answer your simple questions. What chance do I have in finding the answer.
Do you know the sum formula for sine function that says
[tex]sin(a+b)=sina*cosb+cosa*sinb[/tex]?
All I did was replacing
[tex]a=6\pi*x, b=3\pi[/tex]
and while doing the calculations heed that
[tex]cos(3\pi)=-1, sin(3\pi)=0[/tex] .
Do you understand it now?
I took the derivative of the position function with respect to t and used that and the fact that there are 20 buckets and they hold 500 kg. My answer rounded to the one given. Seemed to work ok for me.
Well from using the period of the function I get the exact answer. As I said, the function is actually
The period of this function is 1/3. so, until x=60 this function repeats itself 180 times.
Multiply this by 50*20, and you get the answer.
Could you help me understanding your solution? I still have no idea how to use the deriative.
Like I said, there's a rounding issue, but I did this:
[tex]P(t) = 10 \sin (6 \pi t + 3 \pi) + 20[/tex]
[tex]P'(t) = (10)(6 \pi) \cos (6 \pi t + 3 \pi)[/tex]
Evaluate the derivative at t=60 to calculate the number of times the wheel has gone around:
[tex]P'(60) = 188.45[/tex]
I used absolute value here since the negative value really doesn't mean anything.
To get the total # of kg:
[tex]Total = (188.45 revs)(20 \frac{buckets}{rev})(500 \frac{kg}{bucket})[/tex]
[tex]Total = 1.88 x 10^6 kg[/tex]
I don't see the point still. I mean P'(t) is the velocity and pluggin 60 into this we get the speed of one bucket at time t=60. As far as i am concerned this is not the number of times the wheel has gone around.
Am I wrong?
Wisredz,
You got me to see I forgot a part of my solution!
Evaluate the derivative at t=60 to calculate the number of ANGULAR VELOCITY of the wheel:
[tex]\omega = P'(60) = 188.45 \frac{rad}{min}[/tex]
Now calculate the number of revolutions the wheel has gone thru:
[tex]\theta = (188.5 \frac{rad}{min})(60 min)(\frac{1 rev}{2 \pi rad})[/tex]
[tex]\theta = 1800 rev[/tex]
[tex]Total = (1800 revs)(20 \frac{buckets}{rev})(500 \frac{kg}{bucket})[/tex]
[tex]Total = 18.00 x 10^6 kg[/tex]
Thanks for keeping me honest!
Anytime :)
Mozart, now you have two solutions to choose from. Mine is just a simple trigonometric solution, Fred's is a much more explanatory of the motion because he uses the derivative to find the angular velocity, which gives a lot more info about the info. Both of the solutions give the correct answer so here you go!
Cheers
Hey thanks guys, and sorry for the late response, but some genius decided to put my exam on the day of the prom, and well I was kind of out of it for a few days. Anyways the exam turned out to be quite simple. Nothing was as hard as this question. I know it's not really a hard question for you guys but for me its pretty complicated. Well thanks again.
Actually, Fred's answer is high by a factor of 10.
And you don't need to take the first deriviative to find [itex]\omega[/itex]. The equation you have is of the form :
[tex]x = R sin(\omega t + \phi ) [/tex]
You just have to read off the coefficient of 't' to find the angular velocity [itex] \omega [/itex]. In this case, [itex]\omega = 6 \pi [/itex]. The rest follows as Fred described.
Fred, you found [itex]\dot{x} = v = R \omega[/itex]. You must divide by R = 10, to get the right answer.
ahhhhhhhhhhhhhhhhh...crud. You're right.
1. What topics will be covered on the math exam?
The math exam will cover a range of topics such as algebra, geometry, trigonometry, and calculus. It is important to review all of these topics in preparation for the exam.
2. How many questions will be on the math exam?
The number of questions on the math exam may vary, but it is typically between 50-100 questions. It is important to manage your time wisely and not spend too long on any one question.
3. Will a calculator be allowed on the math exam?
This may vary depending on the exam instructions. Some exams may allow calculators while others may not. It is important to check with your instructor or exam guidelines to see if a calculator is allowed.
4. How can I prepare for the math exam?
To prepare for the math exam, it is important to review class notes, practice problems, and any review materials provided by your instructor. It may also be helpful to work with a study group or seek help from a tutor.
5. What should I do if I am struggling with a particular math question on the exam?
If you are struggling with a particular math question on the exam, do not spend too much time on it. Move on to the next question and come back to it if you have time. If you are still having trouble, try to use any formulas or techniques that you have learned to solve the problem. If all else fails, make your best guess and move on.
  • General Math
