Math Help Needed: Solving Business Finance Problems
  • Thread starter Grits
In summary, the person is trying to solve for r when fv=pv*(1+r)^t. They need to first isolate the (1+r)^t term and then use the fact that r=8% and t=5 to find the time value factors.
Grits
I am new to the site but I need some math help. I am a business major and I am taking Business Finance. He wants us to do a bonus quiz to see how well our math skills are for the class. Well I can't seem to figure them out.
Someone please help.
(1 + r)^2 = 10
(1+r)^2=10
(1+r)(1+r)=10
1+1r+1r+r^2
1+2r+r^2=10
2r+r^2=9
r^2=9-2x/x
r=9-2 =7?
60= [400/ (1 + r)^3]
If PV=110 r=.09 and t=4 find fv when fv= pv*(1+r)^t.
Solve for r directly when FVt=PVo *(1+r)^t
Up to this point, namely [tex]2r+r^2=9,[/tex] your work is ok, but the next line isn't right. There is, however, a more direct solution:
[tex](1+r)^2=10[/tex]
[tex]\sqrt{(1+r)^2}=\sqrt{10}[/tex]
[tex]1+r=\pm\sqrt{10}[/tex]
[tex]r=-1\pm\sqrt{10}[/tex]
As you are new here, I should advise you that most poeple will not reply to your posts unless you show some work.
[tex]60= \frac{400}{(1 + r)^3}[/tex] assume that [tex]r\neq -1[/tex] to get [tex](1 + r)^3= \frac{400}{60}=\frac{20}{3}[/tex]
and then take the cube root of both sides to get... you try.
so does r = 295
(20/3)^3 = 296
r=296-1
Grits said:
so does r = 295
(20/3)^3 = 296
r=296-1
Cube root, one third power. You're cubing it when you should be taking the cube root.
Use
[tex] r = \sqrt[3]{\frac{20}{3}} -1 [/tex]
Cyclovenom said:
Use
how do i put that in my calculator
This is just substitution. [tex]fv=(110)(1+.09)^4[/tex]
Remember to use the order of operations.
Edit: Type this in you calculator: [tex](\frac{20}{3})^{\frac{1}{3}}[/tex], then subtract one from that answer.
2nd Edit: I'm using LaTeX for the first time, and I was wondering if/how you can make the parentheses larger. That looks weird. Could someone please clean that up and make it look better so I can look at the proper code :)?
type (20/3)^(1/3) - 1
Here's another
Solve for r directly when FVt =PVo *(1+r)^t
Grits said:
Here's another
Well what comes first to your mind?
Start by isolationg the (1+r)^t term.
If r=8%, t=5 and m=4 find the timve value factors given below:
FVIF r%/m,t*m=[(1+(r/m))^t*m]
I got 1 as the answer I just canceled out and got 1 left over.
Well actually is basic algebra.
For example:
[tex] a = \frac{bc}{d \sqrt{e}} [/tex]
Now if you want to isolate let's say e what must you do?
first off you could multiply both sides of the equation by [itex] \sqrt{e} [/itex]
[tex] \sqrt{e} a = \frac{ \sqrt{e} bc}{d \sqrt{e}} [/tex]
Now you can see you have
[tex] \sqrt{e} a = \frac{bc}{d} \frac{\sqrt{e}}{\sqrt{e}} [/tex]
Thus
[tex] \sqrt{e} a = \frac{bc}{d}[/tex]
Now you should divide both members by a
[tex] \sqrt{e} \frac{a}{a} = \frac{bc}{da}[/tex]
thus
[tex] \sqrt{e} = \frac{bc}{da}[/tex]
Now using the fact that [itex] \sqrt[n]{e} = e^{\frac{1}{n}} [/itex]
[tex] e^{\frac{1}{2}} = \frac{bc}{da}[/tex]
So if we square both sides
[tex] (e^{\frac{1}{2}})^2 = (\frac{bc}{da})^2[/tex]
Using the fact that [itex] (e^n)^m = e^{nm} [/itex]
[tex] e^{\frac{2}{2}} = (\frac{bc}{da})^2[/tex]
[tex] e = (\frac{bc}{da})^2[/tex]
We succesfully isolated e.
Now try it with your equation.
1. How do I determine the present value of a future cash flow?
The present value of a future cash flow can be determined by using the present value formula, which takes into account the future value, interest rate, and time period. It is calculated by dividing the future value by (1 + interest rate) raised to the power of the number of time periods.
2. What is the difference between simple interest and compound interest?
Simple interest is calculated based on the initial principal amount, while compound interest takes into account the accumulated interest over time. This means that with simple interest, the interest earned each period remains constant, whereas with compound interest, the interest earned increases over time.
3. How do I calculate the return on investment (ROI) for a business?
The ROI for a business can be calculated by dividing the net profit by the total investment and multiplying by 100. This will give you a percentage that represents the return on the initial investment. It is an important measure for evaluating the financial performance of a business.
4. Can you explain the concept of time value of money?
The time value of money is the idea that a dollar received in the future is worth less than a dollar received today. This is due to the opportunity cost of not having that money available to invest or earn interest. In other words, the value of money decreases over time due to inflation and the potential to earn a return on investment.
5. How can I use financial ratios to analyze the financial health of a company?
Financial ratios, such as liquidity, profitability, and solvency ratios, can be used to analyze the financial health of a company. These ratios provide insight into the company's liquidity, profitability, and ability to meet its financial obligations. By comparing a company's ratios to industry benchmarks, you can assess its performance and identify areas for improvement.
