Angle Between 2 Forces of 14lb & 30lb Resulting in 20lb
  • Thread starter dandogg
In summary, to find the angle between two forces, you can use trigonometry. Draw a diagram of the forces and use the law of cosines to find the angle between them. You can also use vector addition to find the total angle between the forces. However, strictly speaking, the term "hypotenuse" only applies to right triangles.
dandogg
hi i was wondering if there was a formula to find the angle between two forces
i.e. two forces of 14lb and 30lb act on a body forming an obtuse angle with each other having a resulting force of 20lbs
Its a trig problem. Draw a picture of the two forces and the resultant force. create two triangles, and label all the sides. then use law of cosines to find one angle, and then the other angle. sum the two angles for the total angle between the two forces.
Theres two ways you can add the two forces to get a net force of 20lbs. One is acute and one is that same angle + 90 deg (obtuse).
You'll want to use vector addition either way.
so if i make a triangle, the largest force of 30would be the hypotenuse and the magnitude and the
other force would be the other two sides?
No, strictly speaking, the term "hypotenuse" only applies to right triangles. It is true, of course, that in your triangle, the sides will have "lengths" 14, 20, and 30. Since the 14 and 30 pound forces are the ones adding, you want the angle between those sides.
Use the cosine law to find that angle.
1. What is the formula for calculating the angle between two forces?
The formula for calculating the angle between two forces is cosθ = (F1•F2)/(|F1||F2|), where θ is the angle between the two forces, F1 and F2 are the magnitudes of the forces, and |F1| and |F2| are the magnitudes of the forces.
2. How do you use the formula to find the angle between two forces?
To use the formula, first find the magnitudes of the two forces. Then, plug the values into the formula and solve for θ. This will give you the angle between the two forces in degrees.
3. What is the angle between two forces of 14lb and 30lb resulting in 20lb?
Using the formula, we can calculate the angle between the two forces as cosθ = (14•30)/(20•20) = 0.63. Taking the inverse cosine of 0.63, we get the angle θ = 51.3 degrees.
4. How does the angle between two forces affect the resulting force?
The angle between two forces affects the resulting force by changing the direction and magnitude of the resulting force. The larger the angle between the two forces, the smaller the resulting force will be. If the angle between the two forces is 90 degrees, the resulting force will be zero.
5. Can the angle between two forces be negative?
No, the angle between two forces cannot be negative. It is always measured as a positive angle between 0 and 180 degrees. If the two forces are acting in opposite directions, the angle between them would be 180 degrees.
