Homework Help: Math. physics
  1. Dec 5, 2011 #1
    Prove
    [tex]\sqrt{\frac{2}{\pi}}\int^{\infty}_0x^{-\frac{1}{2}}\cos (xt)dx=t^{-\frac{1}{2}}[/tex]
    and use that to solve
    [tex]\int^{\infty}_0\cos y^2dy[/tex]
    Is this good way to try to prove?
    2. Relevant equations
    3. The attempt at a solution
    Multiplicate both sides with [tex]\cos x'tdt[/tex] and integrate from zero to [tex]\infty[/tex]
    [tex]\sqrt{\frac{2}{\pi}}\int^{\infty}_0dt\cos (x't)\int^{\infty}_0x^{-\frac{1}{2}}\cos (xt)dx=\int^{\infty}_0dt\cos (x't)t^{-\frac{1}{2}}=\sqrt{\frac{2}{\pi}}\int^{\infty}_0dxx^{-\frac{1}{2}}\int^{\infty}_0dt\cos (x't)\cos (xt)dx[/tex]
  3. Dec 5, 2011 #2
    Suppose that we know
    [tex]\sqrt{\frac{2}{\pi}}\int^{\infty}_0\cos(xt)x^{-\frac{1}{2}}dx=t^{-\frac{1}{2}}[/tex]
    without proving. How to calculate then
    [tex]\int^{\infty}_0\cos x^2dx[/tex]
  4. Dec 5, 2011 #3
    you need to use residue calculus.
    if you can go to library look at hildebrand advanced calculus for applications, under the intended contours you will see how to use cauchy's principle and then you'll get gamma functions.
  5. Dec 5, 2011 #4
    For which part of problem. This is problem from Arfken, Weber.
  6. Dec 5, 2011 #5
    you can do the proof and also find part b when you understand the first part I assume.look hildebrand page 561 to be exact
  7. Dec 5, 2011 #6
    [tex]\int^{\infty}_0\frac{\cos x}{x^{1-m}}dx=\Gamma(m)\cos (\frac{m\pi}{2})[/tex]
    [tex]\int^{\infty}_0\frac{\cos x}{x^{1-\frac{1}{2}}}dx=\Gamma(\frac{1}{2})\cos (\frac{\frac{1}{2}\pi}{2})=\sqrt{\pi}\frac{\sqrt{2}}{2}=\sqrt{\frac{\pi}{2}}[/tex]
    I don't see solution :(
  8. Dec 5, 2011 #7
    you need to look at contour integration and use xt instead of x there. By using residue and appropriate contour you'll be able to find t^-1/2
  9. Dec 5, 2011 #8
    Ok. Thanks. And what then. When I prove first part, how can I calculate integral [tex]\int^{\infty}_0\cos x^2dx[/tex]?
  10. Dec 5, 2011 #9
  11. Dec 5, 2011 #10
    dextercioby
    Take t=1 in what you have proven already then do a simple substitution to get rid of the sqrt.
  12. Dec 6, 2011 #11
    Thanks a lot! :)
Loading...
