Mathcad 14
Tags:
  1. Apr 21, 2012 #1
    I am looking for somebody who knows how to use math cad because I have forwarded the formulas of a form and it does not give me the same result as in my form
    I can send you the doc to help me
    thank you
  3. May 28, 2012 #2
    Can you post the document on the forum (and the worksheet (you will have to zip it))?
  4. May 28, 2012 #3
    I am not sure what you are trying to proove, but if something does not look right...I would type the formulas in a different piece of software to see if mathcad is giving you the right answer or not...I would use either an excel spreadsheet (for ease) or I would work in Python or Fortran or Freemat, something completely different...unless of course, you want to find out if YOUR INSTANCE of mathcad might be the one that is corrupted.
    But if you all you are trying to find out is if the equations have been entered correctly or not...I would use a different program to validate your mathcad output.
  5. May 28, 2012 #4
    That opens up the possibility of a systematic error being introduced into both programs or a different error. It also consumes time!
    It also may not help too much in finding out what's wrong with a worksheet. A problem with the very math-like notation that Mathcad uses is that some errors are not readily discernible from just looking at the worksheet as completely different expressions can look visually the same. For example, an indexed array element can look just like a subscripted name, and an implied multiplication (no visible operator) can look just like a function application. There is no real substitute for looking at the worksheet in many cases.
    NR
    (Not that I'm against multiple, independent ways of checking - I do it myself - but it's not always of particular help).
  6. May 28, 2012 #5
    That's funny, Nemo....it looks to me that you actually made my point, although the "tone" of you writing might have tried to advocate against it. Or I am missing something.
    First, there is no such thing as a systematic error being introduced into two different systems...that's the good thing about being force to type the same formulas into two different systems...if you know what you are doing, with the formulas AND the system...then you should get it right on both.
    Also, it is funny that you said that "there is no real substitute for looking at the [mathcad] worksheet" when right before you indicated several traps with some similar looking equations with different meaning....
    ...so, to that end...there is nothing like good old plain text looking equations like the ones you would need to put together with python, for example.
    Anyway...now for the now for the one piece of advice I always give: "Baby steps...baby steps".
    rottbull: I would recommend you start typing your equations in a different piece of software; you don't need to type EVERYTHING...just one at a time until you find where your answers start diverging between the two systems...that where your problem will be.
  7. May 28, 2012 #6
    I think so.
    There most certainly is. I've done it myself and I've encountered in many times. If I've misread the original text or operated from a given set of incorrect assumptions, then all I will get by implementing my interpretation in n different languages is n + k (where k = number of debugs) different wrong results (and maybe not even the same final wrong result!)
    Your 'if' and 'should' are noted.
    In what way is it funny? I have considerable experience of looking at other people's worksheets and many errors arise from inadvertent use of literal v indicial subscripts or implied multiplication v function calls. They are the kind of thing that new users haven't yet gained familiarity with (or don't yet know) and for experienced users they form the equivalent of the 'missing semi-colon' so beloved of other languages.
    The problem with good old plain text, and the major reason I avoid it like the plague, is that it is often verbose and long expressions get difficult to write correctly and read correctly. There is a reason Mathematics uses more concise notation than FORTRAN and don't get me started on Excel! One of the reasons I use Mathcad is that it is a lot easier to write and verify the implementation against the specification and easier for non-programmers to validate the implementation - summation, integral and factorial operators look familiar and are easier to interpret than code, particularly when the results are presented right alongside.
    No disagreement from me there.
    I would recommend taking those baby steps in Mathcad in the first instance. Break the problem down into smaller steps (indeed, in many cases, this is just a simple matter of evaluating the worksheet at each stage) and check the results make sense.
    I would only resort to another language when getting really bogged down; I learned Python, J, C, C++, C#, FORTRAN, multiple dialects of Basic, Pascal, Modula, ADA, FORTH, LISP,PROLOG, Assembler and goodness knows what else by working within the languages.
    Still, different horse are suited for different courses and it may be that gsal's method works better for you.
    NM
