Mathematica 5.2
  1. Apr 28, 2007 #1
    Hey. I just started using mathematica 5.2, and having a little trouble. When using the Solve[] function, the solutions are given as lists:
    {{t -> a}, {t -> 4}}
    In my next step of calculations, i want to use my second solution. How can i refer to it, instead of having to type it out. Now i know that if the solution was infact 4 that it would be easier to type it, but the solutions are not always as simple.
  3. Apr 28, 2007 #2
    the short answer is:
    t /. {{t -> a}, {t -> 4}}
    The solution is returned in the form of a replacement rule,the " /. " should be read as "replace". (look up the functions Rule and Replace in help). Replacement rules are extremely important.
    When you encounter a puzzling expression, try the function FullForm to see what its made of so you can look up the individual parts in the extensive Built-In help.
  4. Apr 29, 2007 #3
    Ahh yes that makes sense. Thanks for that :smile:
    I now have a new question. I want to solve an equation, but the solution must lie within a restricted range of values. I assumed the following would work:
    Solve[ y[t]==0, t, {t,a,b}]
    However, it doesnt. I had a look at the built in help browser, and wasnt able to come up with anything. What should i do?
  5. Apr 29, 2007 #4
    A simple method in two lines:
    rangeQ[x_] = a ≤ x ≤ b;
    Select[ t/.Solve[y[t] == 0, t] , rangeQ ]
    Using a pure function in one line:
    Select[ t/.Solve[y[t] == 0, t] , a ≤ # ≤ b &]
    This preserves them as rules, rather then values:
    Select[ Solve[y[t] == 0, t] , a ≤ Last[#] ≤ b &]
    Hope that helps.
  6. Apr 30, 2007 #5
    Try "Part" command as Part[Solve[(t - a)*(t - 4) == 0, t], 2, 1, 2]
Similar Threads - Mathematica Date
Mathematica Cannot do the integral of the Hyper-geometric function? Mar 11, 2018
Mathematica Cannot Plot This Function in Mathematica Feb 26, 2018
Mathematica While Loop in Mathematica Feb 25, 2018
Mathematica Mathematica Real Part Feb 24, 2018
Mathematica Polynomial expansion from Python to Mathematica Feb 20, 2018
