Mathematica help.
  • Mathematica
  • Thread starter dukebdx12
can someone help me out with a mathematica problem ( i use mathematica 6)? I have never used this program before and really don't know what to do or where to start. So if someone could give me a little light that would be great.
http://i29.tinypic.com/25rkn5f.jpg
-last graph is g(x,y)=
Answers and Replies
EnumaElish
2,304
124
These must have been produced by Plot3D in Math'ca.
For example,
Plot3D[Cos[x y], {x, -3 \[Pi], 3 \[Pi]}, {y, -3 \[Pi], 3 \[Pi]}]
then shift+enter.
First thing I'd do is to hold & rotate the graph to change the ViewPoint.
To change it explicitly, you can type for example:
Plot3D[Cos[x y], {x, -3 \[Pi], 3 \[Pi]}, {y, -3 \[Pi], 3 \[Pi]}, ViewPoint -> {-1, 0, -3}]
Another thing to try is to change the plot limits from {x, -3 \[Pi], 3 \[Pi]} to (say) {x, -\[Pi], \[Pi]} (same for y).
ok thanks for the reply. my question is, it says make surface and contour plots for suitable intervals, viewpoints, and resolutions. For example f(x,y) = cos(xy) for -3pi <= x,y <= 3pi , that is 1 of the equations for the question. So to make surface and contour plots(many of them) do I just plug other numbers in for -3pi and 3pi? Confused on what I need to do.
EnumaElish
2,304
124
You should make a surface plot and a contour plot for:
a. suitable intervals,
b. suitable viewpoints, and
c. suitable resolutions
for each function f, g, etc.
"Plugging other numbers in for -3pi and 3pi" addresses item a.
i've got it all down now except the resolutions. I have tried searching for it on google and mathematica and i can't find anything on how to do it. It says. to draw surface and contour plots for resolutions. I dont know what that means? can someone explain?
try searching in the master index in mathematica it is very good (help -> master index)
EnumaElish
2,304
124
My guess is, "resolution" means "density" of the plot. For example in a ContourPlot, the number of contours you specify manually, as an option.
Alternatively, resolution can mean sampling frequency. Mathematica has a default sampling frequency when plotting graphs. You can change it by specifying a step size as part of the domain specification. For example:
{x, -\[Pi], \[Pi]} produces default sampling
{x, -\[Pi], \[Pi], \[Pi]/180} produces sampling along the x-axis with step size = 1 degree.
I noticed that a version of convert-pdf was used. If that free trial runs out, try searching for "cute pdf"...
sorry i didn't have anything of much value to add other than that...
EnumaElish
2,304
124
Re my last post above:
If {x, -\[Pi], \[Pi], \[Pi]/180} doesn't work try putting in the option WorkingPrecision -> value in the Plot statement where the default value is MachinePrecision but you can specify a numeric value to increase plot precision (e.g. WorkingPrecision -> 20).
You can also experiment with Mesh and MeshFunctions options. For example:
Plot[Tan[x], {x, 0, Pi/2}, Mesh -> {5, 10}, MeshFunctions -> {#1 &, #2 &}]
I have struggled with bad resolution and quality in RegionPlot for a long time. In particular this is a problem for complicated multiple conditions. The way to solve it is to add PerformanceGoal and MaxRecursion:
RegionPlot[ f(x,y)>0 && g(x,y)>0, {x,xmin,xmax},{y,ymin,ymax},
PerformanceGoal -> "Quality", MaxRecursion -> 8]
I suspect that the default values are PerformanceGoal -> "Speed", MaxRecursion -> 1. The speed and quality seems to be very sensitive to MaxRecursion, so experiment a bit with different values.
( google keywords: resolution RegionPlot Mathematica )
Related Threads on Mathematica help.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
