MATLAB costumers and switches
  1. Apr 5, 2008 #1
    Hey guys i have to do the following:
    we have n customers and m switches, and each switch can accomodate a maximum of c customers (where c > n=m). Write a function which uses a Greedy Algorithm to determine
    which customers should be connected to which switch. it needs to generalise from two switches to m switches.
    The algorithm that needs to be used is the following:
    Code (Text):
    L = 0.75*NC;
    for i = 1:NC
        for j=1:NS
    for i = 1:NC
       if distance(i,1) < distance(i,2)
         if |S1| < L
        S1 = S1 + {i}
         else
        S2 = S2 + {i}
         end if
       else
         if |S2| < L then
         S2 = S2 + {i}
       else
         S1 = S1 + {i}
        end if
      end if
    end
    where NC is the number of costumers
    NS is the number of switches
    S1 and S2 are the set of costumers connected to switch 1 and 2 respectively
    I have done the following code:
    Code (Text):
    %Get the number of customers%
    function retval = blah()
    NC = input('Enter the number of costumers there is: ');
    customers = [];
    %Get each customers co-ordinates and place them into an array%
    for i = 1:NC
    %could also possibly get input as x y ..
       mystr = sprintf('Enter the x value of costumer %i : ',i);
       x = input(mystr);
       mystr = sprintf('Enter the y value of costumer %i : ',i);
       y = input(mystr);
       %Array to hold customers%
       customers = [customers;x y];
    end
    %Get the number of switches%
    NS = input('Enter the number of switches there is: ');
    switches=[];
    %Get each switchs co-ordinates and place them into an array%
    for i = 1:NS
       mystr = sprintf('Enter the x value of switch %i : ',i);
       x = input(mystr);
       mystr = sprintf('Enter the y value of switch %i : ',i);
       y = input(mystr);
       switches = [switches;x y];
    end
    S1=[]; %S1 is the set of costumers connected to switch 1
    S2=[]; %S2 is the set of costumers connected to switch 2
    %Get the maximum number of costumers that the switch can accomandate
    C = input('Enter maximum number of costumers that the switch can accomandate: ');
    if C < (NC/NS)
        frpintf('THis switch cannot be used')
    else
    %the following algorithm is for 2 switches only
    L = 0.75*NC;
    for i = 1:NC
        for j=1:NS
    for i = 1:NC
         if |S1| < L
        S1 = S1 + {i}
         else
        S2 = S2 + {i}
         end if
       else
         if |S2| < L then
         S2 = S2 + {i}
       else
         S1 = S1 + {i}
        end if
      end if
    end
    but its not doing the job. Any suggestions on how i can fix this code up so it does what i need?
    thanks
Draft saved Draft deleted
