MATLAB Function Problem
  • MATLAB
  • Thread starter plexus0208
plexus0208
49
I get the following error with my MATLAB code. Can anyone help me fix it? I don't see what is wrong.
??? Input argument "S" is undefined.
Error in ==> RCPrototype at 11
Wpay = Tmax/((CDA0/S)/CL + cd/CL + CL/(pi*AR)) - Wfuse;
MATLAB CODE:
function [WpayMax, constraint] = RCPrototype(AR, S, lambda)
Wfuse = 2.5;
Tmax = 0.70;
CDA0 = 0.004;
cd = 0.028;
CL = 1.0;
tau = 0.11;
eps = 0.03;
WpayMax = max(abs(Wpay));
constraint = 0.018*((Wfuse + Wpay)/(E*tau*(tau^2+eps^2)))*(1+lambda)^3*(1+2*lambda)*(AR^3);
[WpayMax, constraint] = RCPrototype(0.5,0.5,0.5);
end
Answers and Replies
Dr Transport
Insights Author
714
has S been defined prior to calling the function?? if not, then it isn't defined within the function itself.
jhae2.718
Try calling the function from another M-file. I'm guessing you're trying to directly run the function file.
Also, what are "E" and "lambda" defined as in your function?
caffenta
143
You're calling the function from within the function:
Code:
constraint = 0.018*((Wfuse + Wpay ...
[B][WpayMax, constraint] = RCPrototype(0.5,0.5,0.5);[/B]
end
You need to put that outside the function body.
Suggested for: MATLAB Function Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
