Matlab help with design problem
  1. Apr 27, 2005 #1
    I'm attempting to use Matlab to help me solve a controller design problem...
    I'm using the Polynomial Equations Approach for this design, but I'm getting an error, and a result I wasn't looking for.
    I'm getting an error that reads "Warning: Matrix is singular to working precision."
    Also, the last Matrix M is returning the values NaN for all values...
    My code is bellow. Any help would be appreciated.
    (this post is cross listed in the Electrical Engineering section)
    %Servo Position Controller
    %Using Polynomial Equation Method
    %Defining the vairables in the TF
    Rm = 2.6; %armature resistance
    Km = 0.00767; %Back-emf constant
    Kt = 0.00767; %motor torque constant
    Jm = 3.87*exp(-7); %motor moment of inertia
    Jeq = 2.0*exp(-3); %equivalent moment of inertia at the laod
    Beq = 4.0*exp(-3); %equivalent viscous damping coefficent
    Kg = 70; %srv02 system gear ratio (motor->load) (14X5)
    Ng = 0.9; %gearbox efficiency
    Nm = 0.69; %motor efficiency
    a0 = Jeq*Rm %defining the terms of plant denominator
    a1 = (Beq*Rm + Ng*Nm*Km*Kt*(Kg)^2)
    a2 = 0;
    b0 = Ng*Nm*Kt*Kg %defining terms of plant Numerator
    PlantNum = [b0] %plant numerator
    PlantDenom = [a0 a1 a2] %plant denominator
    PlantTF = tf(PlantNum, PlantDenom); %building the plant transfer function
    %becuase a second order system is desired (from the lab handout)
    %the closed loop poles will be at s^2 + 2s + 1 ie at +-45 degrees from the
    E = [a2, 0, 0, 0; %the Sylvester Matrix E for a plant with the equation
    a1, a2, 0, 0; %like this (0*s^2) + (0*s) + X
    1, a1, b0, 0; % ---------------------
    0, 1, 0, b0;] % (z*s^2) + (y*s) + w
    % D = F*H, D = (s^3) + (2s^2) + s + 0 = (d0*s^3)+(d1*s^2)+(d2*s)+d3
    % D = [d3
    % d2
    % d1
    % d0]
    D = [0;
    M = (inv(E))*D %inverting the Sylvester Matrix and multiplying by D
    %this gives the coefficients which will produce the desired
    % M = [alpha1
    % alpha0
    % beta1
    % beta0]
    %The dseired controller is of the form
    % beta0 + beta1 Beta(z)
    % alpha0 + alpha1 Alpha(z)
Draft saved Draft deleted
Similar Threads - Matlab help design Date
Matlab MATLab: Not enough inputs for nlinfit Nov 16, 2017
Matlab Help needed to fix a matlab code Nov 8, 2017
New to Matlab, help with vectors Feb 20, 2016
Need help with integral Dec 23, 2015
Matlab help with a design problem Apr 27, 2005
