• Support PF! Buy your school textbooks, materials and every day products Here!
Matlab Newton's Method
So, I've written a program that carries out Newton's method. The root of the equation which I am trying to find is approximately 13.1. This is fine and my program returns the correct value when my initial guess is around this value (up to about x = 50 as my initial guess), however when I start using values such as 100+ it returns a complex root. The real part will be approximately 13.1 and the imaginary part will be VERY close to 0. Why is this and is there any way that I can fix/safeguard against this? Thanks.
Code:
function xnew = Newton (f, df, xi, tol)
xold = xi; %x(old) is assigned the value of the initial guess.
xnew = xold - f(xold)/df(xold); %Implement newtons method to find x(new).
k = 0; %Assigns k(the counter) an initial value.
fprintf('\nTable of Iteration No.(k) and Depth(h)\n')
fprintf('\nIteration No.\tDepth\n')
fprintf('%5u\t\t%2.6e\n',k,xi)
while ((abs(xnew - xold))/(abs(xnew)) > tol) %Running condition.
    if (k <= 100) %Max number of iterations.
        xold = xnew; %x(old) get's x(new)'s calculated value as per Newton Method's.
        k = k + 1; %Increment k.
    else
        warning('Maximum number of iterations has been reached')
        break;
    end
    fprintf('%5u\t\t%2.6e\n',k,xnew)
end
Answers and Replies
Yeah, so f and df are both printing out complex values once the initial guess is about 45 and above(remember the actual value of the root is about 13.1) and once the initial guess is about 1000, NaN is returned as the root. This is due to f being Inf + some tiny imaginary number and df being -Inf + some tiny imaginary number. Thus, f/fd will return NaN. First of all, is this due to a problem with my algorithm or is this just a shortcoming of Newton's Method? And second, how can I safeguard against getting imaginary values and values that are too large(i.e. Inf) for f and df? Like, is there a way to check before Newton's Method is carried out to see if the initial guess is valid? Thanks.
Related Threads on Matlab Newton's Method
  • Last Post
29K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
