Matlab ODE15s error message
  1. Apr 21, 2005 #1
    Clausius2
    I am employing the Ode15s subroutine of Matlab for solving some differential equation. But I have obtained the next error message:
    "Warning: Failure at t=-6.718807e-001. Unable to meet integration tolerances without reducing the step size below the smallest value allowed (2.387000e-015) at time t.
    (Type "warning off MATLAB:eek:de15s:IntegrationTolNotMet" to suppress this warning.)
    > In C:\MATLAB6p5\toolbox\matlab\funfun\ode15s.m at line 743"
    I don't know what does it mean, and how can it be solved. If I change the ode solver it remains happening the same.
    Thanks
  3. Apr 21, 2005 #2
    What differential equation are you trying to solve? I think it's either going to be your function is not defined everywhere. For example, you've got a square root or a log and discretisation errors have occured causing the input to become negative.
    Your equation might also have a singularity somewhere, as in y' = y^2, y(0)=1, which is indeed singular at t=1.
  4. Apr 21, 2005 #3
    Clausius2
    Thanks for your reply. This is my problem:
    In order to solve the near field description of a round jet, I want to work out the variables [tex]F(\eta)[/tex] and [tex]Y(\eta)[/tex] which represents the self similar stream function and mass fraction respectively. The system obtained is:
    [tex] (F'Y)''+\frac{F}{2}(F'Y)'=0 [/tex] (1)
    [tex] \Big(\frac{Y'}{Y}\Big)'+\frac{F}{2}Y'=0 [/tex] (2)
    Boundary conditions are:
    1) [tex]\eta\rightarrow\infty[/tex] then [tex] F=C_1+C_2e^{-0.5C_1\eta}(\eta+C_3+2/C_1)[/tex] and [tex] Y=\frac{1}{0.5C_1(\eta+C_3)}[/tex]; ; ;
    2) [tex]\eta\rightarrow-\infty[/tex] then [tex] (F'Y)=Y=1[/tex] and [tex]F=\eta[/tex]
    I have to work out the constants C1, C2 and C3 shooting from +infinite and yielding the boundary conditions at -infinite. My program is:
    __________________________________________________________
    function f=f(eta,y);
    %y1=F; y2=F'/rho; y3=(F'/rho)'; y4=Y; y5=rho*Y'; rho=1/Y;
    %Sistema equivalente:
    %y1'=rho*y2;
    %y2'=y3;
    %y3'=-0.5*y1*y3;
    %y4'=y5/rho;
    %y5'=-0.5*Sc*y1*y5/rho;
    f(1)=y(2)/y(4);
    f(2)=y(3);
    f(3)=-0.5*y(1)*y(3);
    f(4)=y(5)*y(4);
    f(5)=-0.5*y(1)*y(5)*y(4);
    f=f';
    clear; clc; clf; format long;
    %INICIALIZACION DE CONSTANTES
    C1=2.18; %F_inf
    C2=1e-3; %A
    C3=1e-3; %eta_inf
    C=[C1 C2 C3];
    %PARAMETROS DE INTEGRACION
    maxerror=1e-4;
    e=0; %relacion de pesos moleculares;
    S=1; %#Schmidt
    error=10*maxerror;
    iter=0;
    Z=0.01;
    %PLANO COMPUTACIONAL
    etamax=10;
    etamin=-20;
    etao=[etamax etamin];
    h=0.1;
    neta=(etamax-etamin)/h+1;
    %etao=linspace(etamax,etamin,neta);
    %INTEGRACION
    pause;
    while abs(error)>maxerror
    iter=iter+1;
    Y0(1)=C(1)+C(2)*exp(-0.5*C(1)*etamax)*(etamax+C(3)+2/C(1)); %F
    Y0(4)=(0.5*S*C(1)*(etamax+C(3)))^(-1); %Y
    Y0(2)=C(2)*exp(-0.5*C(1)*etamax)*(etamax*(1-0.5*C(1))-0.5*C(1)*C(3)-1)*Y0(4); %(F'Y)
    Y0(3)=-Y0(2)/(etamax+C(3))+C(2)*exp(-0.5*C(1)*etamax)*(1-0.5*C(1))*Y0(4)-0.5*C(1)*Y0(2); %(F'Y)'
    Y0(5)=-1/(etamax+C(3)); %(Y'/Y)
    %options = odeset('RelTol',1e-4,'AbsTol',1e-4);
    options=[];
    [eta,y]=ode15s('f',etao, Y0);<------- HERE'S THE FAILURE LINE
    N=length(eta);
    y=real(y);
    R(1)=y(N,1)-etamin;
    R(2)=y(N,2)-1;
    R(3)=y(N,4)-1;
    error=sum(abs(R));
    pause;
    for i=1:3
    C1=C;
    dC=Z*C(i);
    C1(i)=C1(i)+dC;
    Y01(1)=C1(1)+C1(2)*exp(-0.5*C1(1)*etamax)*(etamax+C1(3)+2/C1(1)); %F
    Y01(4)=(0.5*S*C1(1)*(etamax+C1(3)))^(-1); %Y
    Y01(2)=C1(2)*exp(-0.5*C1(1)*etamax)*(etamax*(1-0.5*C1(1))-0.5*C1(1)*C1(3)-1)*Y01(4); %(F'Y)
    Y01(3)=-Y01(2)/(etamax+C1(3))+C1(2)*exp(-0.5*C1(1)*etamax)*(1-0.5*C1(1))*Y01(4)-0.5*C1(1)*Y01(2); %(F'Y)'
    Y01(5)=-1/(etamax+C1(3)); %(Y'/Y)
    [eta1,y1]=ode15s('f',etao, Y01);
    N1=length(eta1);
    y1=real(y1);
    R1(1)=y1(N1,1)-etamin;
    R1(2)=y1(N1,2)-1;
    R1(3)=y1(N1,4)-1;
    A(1,i)=(R1(1)-R(1))/dC;
    A(2,i)=(R1(2)-R(2))/dC;
    A(3,i)=(R1(3)-R(3))/dC;
    end
    delta=inv(A)*R';
    lambda=-1; %damping factor
    delta=(lambda*delta);
    C=C+delta';
    disp([C iter error]);
    figure(1); subplot(2,2,1); plot(y(:,1),eta); xlabel('F');
    subplot(2,2,2); plot(y(:,2),eta); xlabel('F´/\rho');
    subplot(2,2,3); plot(y(:,4),eta); xlabel('Y');
    pause;
    end
    ___________________________________________________-
    Don't worry about spanish words. Look at the failure line I have bolded. The error points that line. The code is unable to integrate the problem at the first iteration. I don't think the variables are discontinous. I don't know the problem.
  5. Apr 21, 2005 #4
    I can't see any obvious errors. I'd try altering f and see if you get the same errors. Got me stumped to be honest.
  6. Apr 21, 2005 #5
    What is f defined as in the failure line? My understanding is that f is a seperate function file, or needs to be.
    Also, the line above it with options could be a trouble spot.
    Those are the two spots I would look at.
    Oh, try putting an @ in front of f and removing the ' marks. Just a syntax thing, but it will help.
    Those are the three things I would look at first. If none of those work, I am stumped too.
