MATLAB question
  • MATLAB
  • Thread starter smk037
I have been writing a program to compute and change a value a great number of times and writes each value into a file
I did this by continuously storing each value (which is a 7 element vector) into an array, and then writing that into a file using the cvswrite function
The problem I am having is that the array that the array eventually grows to the size that MATLAB gives me an "out of memory" error
so, to fix this, I have been trying to write each value into the .txt file, closing the file, computing the next vector into the same vector that it was computed from (to avoid the memory error), and writing it to the same file, but I can't seem to get it to work
I just end up overwriting the file each time
Is there anyway to get the next vector to print to the next line of the text file, as opposed to just overwriting the initial value in the text file?
any ideas?
Thank you.
Answers and Replies
72
You can open the file with fopen(filename,'a+') and after that fprintf to write to the end of the file.
thanks for the advice
ok, so I've been trying to do something like this
x = [1 2 3 4 5 6]
y = [6 5 4 3 2 1]
fid = fopen('exp.txt', 'wt');
fprintf(fid, '%s\n', y);
fclose(fid)
but again, each time I run the code, the value just gets overwritten
x = [1 2 3 4 5 6]
y = [6 5 4 3 2 1]
fclose(fid)
If you're running this particular block of code repeatedly to generate your file then of course the data will be rewritten. At the end you're closing the file, but when you loop around again you're opening the file and rewriting its contents.
A simple example might help. Suppose that I want to create a file with a list of numbers in it; for the sake of argument, suppose I want to use Matlab to create a file "test.txt" that contains integers from one to ten. An easy way to do it is to use a for loop:
Code:
% First, open the file 'test.txt' for writing.
fid = fopen('test.txt', 'wt');
% Now comes the for loop. At each step of the loop we assign a value to x
% and write this value to the file. The loop starts at x = 1 and continues
% to x = 10
for i=1:10
    x = i;
    fprintf(fid, '%6.2f\n', x);
end
% Now that the loop is finished and we have written the data to the file,
% close the file.
fclose(fid)
The important point to note is that you should close the file only once you've finished adding data to it, not after you add each data point. You should easily be able to modify the above example to work with your array.
Related Threads on MATLAB question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
