Matrices and linear transformations.
In summary, this thread discusses the proposition that all matrices define linear transformations. It is argued that every m x n matrix A over a field k determines a linear transformation T:k^n--->k^m, and conversely, every linear transformation T:V--->W and bases of V and W can be associated with a matrix. It is also noted that matrices can be used in contexts independent of linear maps, but this does not change the fact that every matrix gives a linear map and vice versa. The concept of using colors as labels in the matrix equation is discussed, with the conclusion that while it may not have a physical interpretation, it is still a valid mathematical concept.
  • #71
micromass said:
Well, please define matrix.
Is 1 a number, if 1 + 1 is not defined?
  • #72
Dickfore said:
Yes, it does.
I refer you again to my example then.
  • #73
Dickfore said:
No, it's not similar. We have established that the left matrix can take values from the set [itex]\left\lbrace 0, 1 \right\rbrace[/itex]. In your example 0.1 does not belong to the set. So, his "restrictions" contradict the definition of a matrix. Therefore, it is not a matrix.
So a (0,1)-matrix is not a matrix? http://en.wikipedia.org/wiki/(0,1)-matrix
  • #75
Since we have managed to stray in the field of arbitrariness of definitions, and are not willing to accept the other party's arguments, I decided to back away from this thread.
  • #76
No, not necessarily.
For instance, in abstract algebra {1,2} is a group with multiplication modulo 3.
In particular 1+1 is not defined.
  • #77
I accepted your arguments, but you didn't even acknowledge mine once.
  • #78
Well, the problem seems to be that you never provided a definition of a matrix...
  • #79
Definitions in math are not arbitrary.
To the contrary, they are very sharply defined.
To understand what those definitions are exactly, is now what this whole thread is about.
But I can certainly understand that you had enough of it. ;)
  • #80
Dickfore, I'd bet you are not really agreeing with "the proposition that all matrices define linear transformations" that the OP was trying to prove wrong, regardless of how fortunate his example was.
  • #81
Well I certainly have made folks think.
:biggrin:
However, I don't see much mathematical uses for it.
The first matrix is extendible. I have only shown one row but you could have many rows. In my example this would correspond to many trials of ball withdrawal. However less trivial results might be a connectivity diagram for an electrical network or structural framework.
  • #82
I don't think I agree. For example, the notion of "number" does not seem to have a good definition in mathematics. Should complex numbers be numbers? p-adic numbers? transfinite numbers? I don't know any standard definition of number.
  • #83
Yes, boolean matrices (which are similar) are already used in electical networks. But there you specifically use the structure of boolean algebras.
  • #84
:biggrin:
Thanks, it's been fun, and we might have set up some record for brief and fast posting not counting the non-science subforums (almost 60 posts in a little over 2 hours).
  • #85
  • Linear and Abstract Algebra
