Solve for A-1 in Matrix Equation w/A, I
  • Thread starter rock.freak667
  • Tags
    Matrices
In summary, the Matrix Equation w/A, I is a mathematical formula used to solve for A-1, the inverse of a matrix. A-1 is important because it allows us to find the original values or conditions that resulted in the given matrix. The steps to solve for A-1 involve rewriting the equation as A * A-1 = I and using elementary row operations to convert A into the identity matrix. However, A-1 can only exist if A is a square matrix with a non-zero determinant.
rock.freak667
6,223
31
A square matrix A satisfies the matrix equation A3-3A2+7A-2I=0.
If A-1 exists, find an expression for A-1 in terms of A and I
I just multiplied the matrix equation by A-1 and then rearranged to get
2A-1 =3A-7I-A2
Is it that easy? Or is there something that I am missing?
Yes I suppose that is all, although you might want to check your signs.
ok thanks..will do.
What is the Matrix Equation w/A, I?
The Matrix Equation w/A, I is a mathematical formula used to solve for a variable, in this case A-1, in a matrix. The A represents the coefficient matrix and the I represents the identity matrix.
What is A-1?
A-1, also known as the inverse of A, is a matrix that when multiplied by A results in the identity matrix. In other words, it "undoes" the effects of A.
Why is it important to solve for A-1?
Solving for A-1 is important because it allows us to find the original values or conditions that resulted in the given matrix. It is also useful in solving systems of linear equations and performing other mathematical operations on matrices.
What are the steps to solve for A-1 in a Matrix Equation?
The steps to solve for A-1 in a Matrix Equation are as follows:
  1. Write out the Matrix Equation w/A, I
  2. Rewrite the equation as A * A-1 = I
  3. Use elementary row operations to convert the coefficient matrix A into the identity matrix I
  4. The resulting matrix will be the inverse of A, A-1
Are there any conditions or restrictions to solving for A-1?
Yes, in order for A-1 to exist, the coefficient matrix A must be a square matrix and must have a non-zero determinant. If the determinant of A is equal to 0, then A-1 does not exist.
