Understanding Matrices: Exploring the Solutions for det|P|
  • Thread starter synkk
  • Tags
    Matrices
In summary, the conversation discusses the confusion between uppercase and lowercase variables and the notation for the determinant of a matrix. It is clarified that |P| does not mean "absolute value" of P but rather the determinant of P, and the correct notation should be |det P| or |det(P)|. The solution to 4|det P|=12 is x=±3 because both 3 and -3 satisfy the equation when plugged back in. Therefore, the determinant of P can be either 3 or -3. The conversation ends with the understanding of the solution and the topic.
synkk
216
For part b:
Could anyone why it is + or - 3? I really don't understand why there would be two solutions as det|P| as it would just be the absolute value of P, meaning just +ve?
synkk said:
For part b:
It's "±" because your equation has the absolute value of the determinant of p .
synkk said:
For part b:
You seem to be confusing P (the matrix) and p (a number). Uppercase and lowercase are significant here, and you seem to be ignoring the difference.
The notation |P| doesn't mean "absolute value" of P; it is the determinant of P, also written as det(P).
What you show as |det p| makes no sense, because you're not taking the deteriminant of the number p - you want the determinant of the matrix P.
Why?
What is shown in the OP is what the book has shown, not me.
Thanks for your input so far.
OK, then that's an error in the book. Apparently the author got confused between P and p.
What is written as |det p| should be written as |det P| or |det(P)|.
Since |det (P)| = 3, then det(P) = ± 3.
synkk said:
Why?
The solution to
4|x|=12
is
x = ±3 .
Do you agree?
SammyS said:
The solution to
4|x|=12
is
x = ±3 .
Do you agree?
No I've never learned this before, could you explain it please?
the solution to 4|x|=12 is x=±3 BECAUSE if you plug x back in it works for both 3 and -3 ie. if you only list one of these as a solution then you have not completely solved the equation.
Therefore if you have 4|det P|=12 then |det P| = 3 meaning that det P can be either 3 or -3
make sense?
The solutions to |y| = k, where k > 0 are y = k or y = -k.
make sense?
yes, thank you and to everyone else.
1. What is a matrix and how is it used in mathematics?
A matrix is a collection of numbers arranged in a rectangular or square grid. It is used in mathematics to represent and solve systems of linear equations, transform geometric shapes, and perform calculations in various areas of science and engineering.
2. What is the determinant of a matrix and why is it important?
The determinant of a matrix is a value that can be calculated from the elements of the matrix and represents the scaling factor of the linear transformation described by the matrix. It is important because it is used to determine if a matrix is invertible, and it also has applications in solving systems of linear equations and finding eigenvalues.
3. How do you find the determinant of a matrix?
The determinant of a matrix can be found by using the formula det|A| = a11b22 - a12b21, where a11 and b22 are the elements of the main diagonal and a12 and b21 are the elements of the other diagonal. This formula can be extended to larger matrices by using the Laplace expansion method.
4. What is the relationship between the determinant and the solutions of a matrix?
The determinant of a matrix can be used to determine the number of solutions for a system of linear equations represented by the matrix. If the determinant is non-zero, then the system has a unique solution. If the determinant is equal to zero, then the system has either no solutions or infinitely many solutions.
5. Can the determinant of a matrix be negative?
Yes, the determinant of a matrix can be negative. The sign of the determinant depends on the order of the rows and columns in the matrix. If the number of row exchanges needed to bring the matrix to upper triangular form is odd, then the determinant will be negative. Otherwise, it will be positive.
  • Linear and Abstract Algebra
