Homework Help: Matrix exponential problem
  1. Oct 20, 2011 #1
    Given matrix A= [1,1;0,0] and matrix B = [1,-1;0,0]
    n.b. the semicolon separates the matrix rows
    find exp(A)exp(B)
    2. Relevant equations
    [itex]exp^{A}=\sum\frac{A^{n}}{n!}=I + A + \frac{A^{2}}{2} + \frac{A^{3}}{6} + ...... + \frac{A^{n}}{n!}[/itex]
    for n= 0 to infinity
    3. The attempt at a solution
    The answer the tutor give is the following matrix
    exp(A).exp(B) = [e^2,-(e-1)^2 ; 0,1]
    this would imply that A and B are diagonalisable (since they need to be in order to get the form of the answer)
    However, if I worked out the characteristic ppolynomial of A and B, I would only get one eigenvalue, not two distinct eigenvalues which rules out any chance of diagaonlisation
    Is there a way to diagaonlise A and B ?
  3. Oct 20, 2011 #2
    Mark44
    Staff: Mentor
    I get two eigenvalues for each matrix, so I don't know what you did that you came up with only one apiece.
  4. Oct 20, 2011 #3
    Mark44
    Staff: Mentor
    You can also do this problem without diagonalizing either matrix. Use your relevant equation, which should be slightly amended. It's not a finite sum.
    [tex]exp^{A}=\sum\frac{A^{n}}{n!}=I + A + \frac{A^{2}}{2} + \frac{A^{3}}{6} + ...... + \frac{A^{n}}{n!} + ...[/tex]
  5. Oct 20, 2011 #4
    Ray Vickson
    A standard result for an nxn matrix with all eigenvalues different is: if r_1, r_2,...,r_n are the eigenvalues, there exist matrices E_1,E_2,...,E_n such that for any analytic function f(x) = sum c_n x^n (with radius of convergence containing all the r_j) then f(A) = c_0*I + c_1*A + c_2*A^2 + ... = sum_j f(r_j)* E_j . Here the E_j are the same for any f, so cn be found, for example, by looking at f(x) = 1 = x^0, f(x) = x, f(x) = x^2, etc. Having the E_j, now use f(x) = exp(x) to get exp(A).
    For a 2x2 matrix with eigenvalues 'a' and 'b' we have I = E1 + E2, which comes from using f(x) = 1. Similarly, A = a*E1 + b*E2 (using f(x) = x).
    RGV
  6. Oct 20, 2011 #5
    What was your characteristic polynomial for A ? What eigenvalues did you get for A ?
    Also, what char. polynomial and eigenvalues did you get for B ?
  7. Oct 20, 2011 #6
    HallsofIvy
    Those are both "Jordan form" matrices so the numbers on the diagonal are the eigenvalues.
  8. Oct 20, 2011 #7
    vela
    Staff Emeritus
    Education Advisor
    What did you get?
  9. Oct 20, 2011 #8
    I got 0 and 1 as the eigenvalues for both matrix A and Matrix B.
    The characteristic polynomial I got for A was [itex]λ^{2}-λ[/itex]
    Similary, my char. polynomial for B is [itex]λ^{2}-λ[/itex]
  10. Oct 20, 2011 #9
    vela
    Staff Emeritus
    Education Advisor
    So you got two distinct eigenvalues, and you can diagonalize them both.
    As Mark mentioned, you can calculate eA and eB without diagonalizing though. A matrix satisfies its characteristic polynomial, so A2-A=0. Using that fact, you can easily simplify the series.
  11. Oct 21, 2011 #10
    Thanks for that. I was asking in the first placecause I knew the diagonal form of both A and B would be
    [ 0, 1 ; 0, 0]
    which is nowhere close to the tutor's answer
  12. Oct 21, 2011 #11
    vela
    Staff Emeritus
    Education Advisor
    That's not the diagonal form of either A or B.
    Also, your tutor calculated exp(A)exp(B), which isn't the diagonalization of A or B.
  13. Oct 21, 2011 #12
    but doesn't the Diagonal matrix contain the eigenvalues down the main diagonal and 0's elsewhere ?
    what don't I understand ?
  14. Oct 21, 2011 #13
    vela
    Staff Emeritus
    Education Advisor
    The matrix you wrote was
    \begin{pmatrix} 0 & 1 \\ 0 & 0 \end{pmatrix}which isn't diagonal.
Loading...
