Homework Help: Matrix Exponentials
  1. Apr 14, 2012 #1
    Let B =
    |1 -2|
    |1 3 |
    Let C =
    |1 4 0|
    |0 1 0|
    |0 0 2|
    Find e[itex]^{B}[/itex] and e[itex]^{C}[/itex]
    2. Relevant equations
    e[itex]^{A}[/itex] = [itex]\Sigma[/itex]x[itex]^{n}[/itex]/n!
    e[itex]^{A}[/itex] = P[itex]^{-1}[/itex]e[itex]^{D}[/itex]P
    3. The attempt at a solution
    My professor told me the first step to approaching these types of problems is to find the eigenvalues for both B and C. For B, I get eigenvalues 2+i and 2-i, and I get 1 (double root) and 2 as the eigenvalues for C.
    I'm having trouble finding some eigenvectors for B (my teacher did not provide any sufficient or clear examples of eigenstuff involving complex numbers), and I get [1, 0, 0] and [0, 0, 1] as my eigenvectors for C (for e-values 1 and 2, respectively).
    I'm sure at this point I'm supposed to construct P, P[itex]^{-1}[/itex] and D for each and somehow use those to find e[itex]^{B}[/itex] and e[itex]^{C}[/itex], but I'm not sure how to go about doing that since my professor did not clearly explain the entire process...
  3. Apr 14, 2012 #2
    morphism
    You should look in a linear book (or online) to see how one typically finds eigenvectors. And while you're at it, look up "diagonalization".
    The point of diagonalization here is this: if D is diagonal, say with entries d_1, ..., d_n down the diagonal, then e^D will be diagonal entries ##e^{d_1}, \ldots, e^{d_n}## down the diagonal. This makes the formula you quoted (##A=P^{-1}PD \implies e^A=P^{-1}e^DP## handy.
    Just a tip: the matrix C will turn out to not be diagonalizable. But if you look at it, it's clearly "block" diagonal. So by the same token, it will turn out that e^C will be block diagonal with e^{2x2 block of C} for the first block and e^2 for the second.
    So now you have to compute the exp of ##\left(\begin{smallmatrix} 1&4\\0&4 \end{smallmatrix}\right)##. For this, I recommend directly using the Taylor series of exp and trying to spot the pattern.
  4. Apr 14, 2012 #3
    Ray Vickson
    You don't need the eigenvectors. It is the case that for any analytical function
    [tex] f(x) = c_0 + c_1 x + c_2 x^2 + \cdots,[/tex] if we define f(A) for an nxn matrix A as [tex] f(A) = c_0 I + c_1 A + c_2 A^2 + \cdots,[/tex] then: if the eigenvalues of A are r1 with multiplicity m1, r2 with multiplicity m2, ... we have: there are matrices E_11,...., E_1m1, E_21,...,E_2m2,... such that
    [tex]f(A) = \sum_{j=1}^{m_1} E_{1j} f^{(j-1)}(r_1) +
    \sum_{j=1}^{m_2} E_{2j} f^{(j-1)}(r_2) + \cdots,[/tex]
    where [itex] f^{0}(r) = f(r), \, f^{(1)}(r) = f^{\prime}(r), \; f^{(2)}(r) = f^{\prime \prime}(r), [/itex] etc. Here, the matrices E_{ij} are independent of the form of the function f.
    For the case of C, this says
    [itex] f(C) = E_{11}f(1) + E_{12}f'(1) + E_{21} f(2)[/itex] for any f. In particular, if you apply this to f(x) = 1 (f(C) = I), f(x) = x (f(C) = C) and f(x) = x^2 (f(C) = C^2) you can get the matrices [itex] E_{11}, E_{12}, E_{22}.[/itex] Then [itex] e^C = E_{11}e^1 + E_{12} e^1 + E_{22} e^2 = (E_{11} + E_{12}) e^1 + E_{22} e^2.[/itex]
    RGV
