Is there a theorem that guarantees this?
In summary: Can you think of a way to prove that?In summary, if a matrix is invertible, then it must be an nxn matrix and the determinant cannot equal to 0. If the rows are not scalar multiples of each other, then any 2x2 submatrix of the matrix will have a determinant not equal to 0.
MathNoob22
Let A be a 2x3 matrix with real coefficients, and suppose that neither of the two rows of A is a scalar multiple of the other. By quoting an appropriate theorem from linear algebra, show that for some j [tex]\in[/tex] {1,2,3}, the 2x2 matrix obtained by omitting the jth column of A is invertible
Not really any necessary equations that I can think of. Only one I suppose is:
AA[tex]^{-1}[/tex] = I
So A has to be a square matrix in order for it to be invertible.
I know in order for a matrix to be invertible, it has to be an nxn matrix. Also, the determinant of A cannot be equal to 0. So, if the rows are not multiples of each other, does that automatically mean that any 2x2 submatrix of A have a determinant not equal to 0?
Any help would be appreciated!
Write it out and solve the equations: if [tex]\det \left( \begin{array}{cc} a & b \\ c & d \\ \end{array} \right) \neq 0[/tex], what does that tell you about the relationship between [tex](a \,\, b)[/tex] and [tex](c \,\, d)[/tex]?
I know then that ad-bc[tex]\neq[/tex]0. But I don't know where to go after that. :( I think I have to use the Gram-Schmidt process, but I'm not sure. Help please?
You can deduce from whether [tex]ad - bc = 0[/tex] whether there exists any [tex]\beta[/tex] such that [tex](a\,\,b) = \beta(c\,\,d)[/tex] or [tex]\beta(a\,\,b) = (c\,\,d)[/tex]. Think about the ratios [tex]c/a[/tex] and [tex]d/b[/tex], or their inverses if one of [tex]a[/tex] and [tex]b[/tex] is zero.
The ratios should be equal to the constant [tex]\beta[/tex], but that's assuming that ad-bc=0. If that was the case, then that matrix wouldn't be invertible. Am I misunderstanding something?
My point is that you can prove (and you should) that this implication goes in both directions: one row is a constant multiple of the other if and only if [tex]ad - bc = 0[/tex].
Wow, that's actually pretty obvious. If the rows aren't scalar multiples of each other, than the determinant can't possible equal to 0. And if the determinant isn't equal to 0, then the matrix is invertible!
One last problem, do we have to prove anything about omitting a column? I thought that was the brunt of the problem, and that was what was throwing me off.
Thanks for all the help so far!
Well, you need to take the fact that neither row of the original matrix [tex]A[/tex] is a scalar multiple of the other, and conclude from that that one of the three possibilities after a column is omitted still has this property. There is a small argument you need to make there.
I can't think of how to prove that any 2x2 matrix left over by omitting one of the columns will be guaranteed to be non-scalar multiples. The matrix I have in mind is:
[tex]
\left( \begin{array}{cc} 3 4 7 \\ 6 8 8 \\ \end{array} \right) \
[/tex]
If I omit column j=3, I'll have a 2x2 matrix with rows that are scalar multiples. Since they are scalar multiples, they're determinant is equal to 0, and thus not invertible. If they're not invertible, then it doesn't work by omitting ANY column, but only a column that would leave a matrix that have no scalar rows.
1. What is the Matrix Inversion Problem?
The Matrix Inversion Problem refers to finding the inverse of a square matrix, which is a matrix that can undo the effects of another matrix when multiplied together. In simpler terms, it is finding a matrix that when multiplied with the original matrix, results in the identity matrix.
2. Why is the Matrix Inversion Problem important?
The Matrix Inversion Problem is important in various fields such as engineering, physics, and computer science. It is used to solve systems of linear equations, calculate determinants, and perform transformations in computer graphics and image processing.
3. How is the Matrix Inversion Problem solved?
The Matrix Inversion Problem can be solved using various methods such as Gaussian elimination, LU decomposition, or using the inverse matrix formula. The method used depends on the size and complexity of the matrix.
4. What are the challenges of solving the Matrix Inversion Problem?
One of the main challenges of solving the Matrix Inversion Problem is dealing with singular matrices, which do not have an inverse. Another challenge is the computational complexity, as the time and resources required to solve the problem increases with the size of the matrix.
5. Are there any applications of the Matrix Inversion Problem?
Yes, the Matrix Inversion Problem has various applications in fields such as data analysis, signal processing, and quantum mechanics. It is also used in machine learning algorithms such as linear regression and principal component analysis.
