1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Matrix problem
  1. Nov 1, 2008 #1
    Matrix A is
    -4 4 4
    -4 4 4
    4 -4 -4
    It has two real eigenvalues, one of multiplicity 1 and one of multiplicity 2. Find the eigenvalues and a basis of each eigenspace.
    3. The attempt at a solution
    I got the eigenvalues:
    the one of multiplicity 1 is -4
    the one of multiplicity 2 is 0
    I can also get the eigenvectors for both:
    for -4 : [1 1 -1]^T
    for 0: [2 1 1]^T
    But... I don't know where to go from here. At all. Any help would be greatly appreciated.
  3. Nov 1, 2008 #2
    gabbagabbahey
    Remember, when you diagonalize a matrix you get [itex]D=P^{-1}MP \Rightarrow M=PDP^{-1}[/itex] not just [itex]M = D[/itex]. This means that
    [tex]M^n=(PDP^{-1})^n=(PDP^{-1}) \cdot (PDP^{-1}) \cdot (PDP^{-1}) \ldots (PDP^{-1})=PD(P^{-1}P)D(P^{-1}P)\ldots DP^{-1}=PD^nP^{-1}[/tex]
    So, while you have correctly calculated [itex]D^n[/itex], you forgot to multiply it by [itex]P[/itex] and [itex]P^{-1}[/itex] to get [itex]M^n[/itex].
    Edit-this was in reply to the original question ;0)
  4. Nov 1, 2008 #3
    gabbagabbahey
    Your second eigenvector is incorrect. You should also be looking for two (generalized) eigenvectors for [itex]\lambda=0[/itex] since that eigenvalue has multiplicity of 2.
    Your first eigenvector [itex]x[/itex] will be given by [itex](A-\lambda I)x=0[/itex] but(!) your second one will not. Your matrix A is degenerate, and so you need to look for generalized eigenvectors. In this case, since [itex]\lambda=0[/itex] has multiplicity two, its eigenvectors are given by [itex](A-\lambda I)x=Ax=0[/itex] and [itex](A-\lambda I)^2x=A^2x=0[/itex].
  5. Nov 1, 2008 #4
    edit: oh okay, so the eigenvectors for 0 are:
    (1, 1, 0)
    (1, 0, 1) ?
  6. Nov 1, 2008 #5
    gabbagabbahey
    Yup!:smile:
  7. Nov 1, 2008 #6
    Sweet, how do I get eigenspaces though? To be honest, I'm not even sure what they are...
  8. Nov 1, 2008 #7
    gabbagabbahey
    So, what is the eigenspace of the [itex]\lambda=-4[/itex] eigenvalue? How about the [itex]\lambda=0[/itex] eigenvalue.
  9. Nov 1, 2008 #8
    HallsofIvy
    Staff Emeritus
    You already have two eigenvectors for the space of eigenvectors corresponding to eigenvalue 0, <1,1,0> and <1, 0,1>. Since those are not multiples of one another, they are independent. Two independent vectors in a space of dimension 2? What does that tell you about a basis?
  10. Nov 1, 2008 #9
    So... For eigenvalue -4, the eigenspace would just be the eigenvector? Like [-1, 1, 1]?
    And for the 0, it'd be:
    [1 1]
    [1 0]
    [0 1]?
  11. Nov 1, 2008 #10
    gabbagabbahey
    For the -4, the eigenspace is just <1,1,-1>.
    And for the eigenvalue zero, the eigenspace is {<1,1,0>,<1,0,1>} (that is the set of the two vectors)
    Clearly, the eigenspace of the -4 eigenvalue is 1D, while the eigenspace of the eigenvalue zero is 2D
  12. Nov 1, 2008 #11
    HallsofIvy
    Staff Emeritus
    No, no, no! An eigenspace is never a single vector. The eigenspace corresponding to eigenvalue -4 is the subspace spanned by {<1, 1, -1>} or having that set as basis.
    Similarly, the eigenspace corresponding to eigenvalue 0 is NOT "{<1, 1, 0>, <1, 0, 1>}, it is the subspace spanned by that set or having that set as basis.
Similar Discussions: Matrix problem
  1. Matrix problem (Replies: 1)
  2. Matrix problem (Replies: 4)
  3. Matrix problem (Replies: 4)
  4. Matrix Problem (Replies: 6)
  5. Matrix problem (Replies: 11)
Loading...
