Matrix proofs
  1. Apr 20, 2013 #1
    First Question: Be A and B square matrix. Show that if A and B are invertible matrix, then: (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1)
    3. The attempt at a solution
    First Queston: (A+B)^(-1) = [A^(-1) + A^(-1)*B*A^(-1)]^(-1) (I distributed the a^(-1) outside the []). Then I don't know what else I can do
    Second Question: Be A and P matrix of nxn dimension with P being invertible. So det (P^(-1)*A*P) = det(A)
    I would like to transform the (P^(-1)*A*P) into (I*A), but since matrix multiplication ain't commutative, I don't know how to get there
  3. Apr 21, 2013 #2
    jbunniii
    You can verify this by showing that
    $$(A+B)(A^{-1}[I + BA^{-1}]^{-1}) = I$$
    What properties of determinants do you know about?
  4. Apr 21, 2013 #3
    I was only able to develop it until here:
    [itex]A(A^{-1}[I + BA^{-1}]^{-1}) + B(A^{-1}[I + BA^{-1}]^{-1}) =[/itex]
    [itex]AA^{-1}[I + BA^{-1}]^{-}) + BA^{-1}[I + BA^{-1}]^{-1} = [/itex]
    [itex]I[I + BA^{-1}]^{-1} + BA^{-1}[I + BA^{-1}]^{-1} = [/itex]
    [itex][I + BA^{-1}]^{-1} + B[A^{-1} + A^{-1}BA^{-1}]^{-1} = [/itex]
    I know that de determinant of A^(-1) = 1/ det A, that det A = det A transpose, that the det A with a constant K that multiplies one of its lines is equal to K that multiplies det A and so that if this constant multiplies all lines. then det A = K^n * det A
  5. Apr 21, 2013 #4
    Dick
    I think the problem is asking you to assume that the wrong things are invertible. A and B invertible doesn't show A+B is invertible. You need to assume that everything is invertible. Then for the first use that C^(-1)D^(-1)=(DC)^(-1). Figure out what to put D and C equal to.
  6. Apr 21, 2013 #5
    jbunniii
    Now try using the distributive property.
  7. Apr 21, 2013 #6
    jbunniii
    Another important property: ##\det(AB) = \det(A)\det(B)##. Do you know this one? If so, the second problem should be easy.
  8. Apr 22, 2013 #7
    How? The identity is irrelevant, so only the [itex]a^{-1}[/itex] is left, and I already distributed it without seeing any meaningful result
    Ah yes, had forgotten this one.
    Didn't really understand. Can you try to explain it once more?
  9. Apr 22, 2013 #8
    Dick
    What I mean is take the inverse of both sides of (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1). What you first did, distributing the A^(-1) inside of the [] is quite wrong. There's a ^(-1) on the bracket.
  10. Apr 22, 2013 #9
    jbunniii
    Both terms have a common factor on the right, namely ##(I + BA^{-1})^{-1}##:
    $$I(I+BA^{-1})^{-1} + BA^{-1}(I+BA^{-1})^{-1}$$
    So factor out that common term and see what you get.
  11. Apr 24, 2013 #10
    Yes, I have to admit that I was suspicious about this distributive. Thanks for pointing it out.
    I see it now. Thanks
Have something to add?
Draft saved Draft deleted
Similar Discussions: Matrix proofs
  1. Matrix Proof (Replies: 9)
  2. Matrix Proof (Replies: 1)
  3. Matrix Proof (Replies: 6)
  4. Matrix proof (Replies: 3)
  5. Matrix proof (Replies: 8)
Loading...
