Homework Help: Matrix Question!
  1. Nov 8, 2007 #1
    The problem statement, all variables and given/known data
    Give the following matrix A = [2 1; 3 2] show that (A^2)-4A+I=0 where I is the 2x2 identity matrix. Hence use your result to deduce the inverse of A.
    The attempt at a solution
    I can do the show part no problem, but I'm stuck on how to find inverse of A. I multiply both sides of the equation by inverse A and get..
    (A^-1)(A^2) - 4A(A^-1) + I(A^-1) = 0(A^-1)
    Can you apply index laws on matrices? Any suggestions on what I should do next? Thanks!
  3. Nov 8, 2007 #2
    Dick
    The equation you just wrote simplifies to A-4I+A^(-1)=0. Do you see how? Can you solve that for A^(-1)? You were practically done!
  4. Nov 8, 2007 #3
    yeah i see now, was just unsure whether I could apply index law for the first set of terms. just to refresh my memory!
    So any matrix multiplied by its inverse gives the identity matrix of the same dimensions and
    any matrix multiplied by the identity matrix gives the original matrix
  5. Nov 8, 2007 #4
    Dick
    What index law? You are just using A*A^(-1)=I. You mean A^n*A^m=A^(n+m)? Sure you can.
  6. Nov 8, 2007 #5
    Yeah I just wanted to know if you could use A^n*A^m=A^(n+m).
    Now everything is ok!
  7. Nov 9, 2007 #6
    HallsofIvy
    It's not really a matter of exponents (not "indices"), just the distributive law. You already know that (A^2)-4A+I=0 so obviously 4A- A^2= A(4I-A^2)= I. Now use the definition of "multiplicative inverse".
  8. Nov 9, 2007 #7
    Note that A does not have an inverse iff the characteristic polynomial has zero as a root iff the constant term of the characteristic polynomial is zero.
  9. Nov 10, 2007 #8
    HallsofIvy
    Yes, but the fact that (A^2)-4A+I=0 shows that neither of those is true!
