Matrix Questions: Solve A^3, C^2003, f(A), e^C & Square Roots of A
  • Thread starter niteshadw
  • Tags
    Matrix
In summary, the process for solving A^3 involves multiplying A by itself three times. To calculate C^2003, you would find the eigenvalues and eigenvectors of C, raise each eigenvalue to the power of 2003, and multiply it by the corresponding eigenvector. f(A) represents the function of A, and can be useful in solving certain problems. To calculate e^C, you would find the eigenvalues and eigenvectors of C, raise e to the power of each eigenvalue, and multiply it by the corresponding eigenvector. It is possible to take the square root of a matrix A by finding the eigenvalues and eigenvectors of A, taking the square root of each eigenvalue
niteshadw
Let
A =
2 0
4 1
B =
2 0 −4
3 −2 6
C =
5 0 0
0 −1 0
0 0 0
and let f(t) = t^2 - 5t + 2. Compute the following if possible.
(a) A^3
(b) C^2003
(e) f(A)
(g) We define the matrix exponential by the Taylor series:
e^C = I + C + 1/2! * C^2 + 1/3! * C^3 + · · · + 1/n! * Cn + · · · .
Calculate e^C
(2)
An n × n matrix S (with real entries) is called a square root of the n × n matrix A (with real entries), if S2 = A.
Find the square roots of the matrix
A=
1 3
0 1
I don't have an idea on how to do the problems just posted, I can do the rest and those that I did not post, but I never learned #2 and I don't know how to take powers of matrix nor recall series. Would anyone be kind enough to explain how to do these problems. It would be very much appreciated. Thank you.
niteshadw said:
(1)
(a) A^3
(b) C^2003
(e) f(A)
Calculate e^C
(2)
A=
1 3
0 1
Well if you know matrix multiplication, 1a shouldn't be a problem. Calculate:
[tex]
\left( {\begin{array}{*{20}c}
2 & 0 \\
4 & 1 \\
\end{array} } \right) \cdot \left( {\begin{array}{*{20}c}
2 & 0 \\
4 & 1 \\
2 & 0 \\
4 & 1 \\
[/tex]
The power 2003 seems horrible, but C is a diagonal matrix and that has a handy property for powers. This should make 1b and 1g possible.
[tex]
a & 0 & 0 \\
0 & b & 0 \\
0 & 0 & c \\
\end{array} } \right)^n = \left( {\begin{array}{*{20}c}
{a^n } & 0 & 0 \\
0 & {b^n } & 0 \\
0 & 0 & {c^n } \\
[/tex]
For 1e, simply follow the instructions. I assume the constant will have to be multiplied with the unity matrix.
[tex]
f\left( A \right) = A^2 - 5A + 2 = \left( {\begin{array}{*{20}c}
2 & 0 \\
4 & 1 \\
\end{array} } \right)^2 - 5\left( {\begin{array}{*{20}c}
2 & 0 \\
4 & 1 \\
\end{array} } \right) + 2\left( {\begin{array}{*{20}c}
1 & 0 \\
0 & 1 \\
[/tex]
For 2, you know you have to start with a 2x2 matrix. Take a general one, take the square and identify the elements. This will give a fairly easy system.
[tex]
1 & 3 \\
0 & 1 \\
\end{array} } \right) = \left( {\begin{array}{*{20}c}
a & b \\
c & d \\
\end{array} } \right)^2 = \left( {\begin{array}{*{20}c}
a & b \\
c & d \\
a & b \\
c & d \\
{a^2 + bc} & {ab + bd} \\
{ac + cd} & {bc + d^2 } \\
[/tex]
You know how to multiply matrices together right? That's all powers are, A^2=AxA, A^3=AxAxA, etc. (the little "x" meaning "times" here)
For the huge power C^2003, find C^2, C^3, C^4, ... as many as you need to until you see a pattern. You should be able to write a nice general expression for C^n, which will help for part (g).
For part (g), use your expression for C^n to write each entry of e^C as an infinite sum. The usual series for e^x where x is a real number is the same as the one they've given for e^C with C's and x's interchanged, so you should be able to write e^C in a nice form using this.
For the square root question, this will seem like a lame suggestion but it doesn't look like you're expected to know a general method to compute the square root of a matrix (when it exists). So try to guess an S that works here. Maybe computing some powers of A will give you some inspiration.
[tex]
2 & 0 \\
4 & 1 \\
2 & 0 \\
4 & 1 \\
2 & 0 \\
4 & 1 \\
[/tex]
[tex]
a & 0 & 0 \\
0 & b & 0 \\
0 & 0 & c \\
{a^n } & 0 & 0 \\
0 & {b^n } & 0 \\
0 & 0 & {c^n } \\
[/tex]
[tex]
2 & 0 \\
4 & 1 \\
2 & 0 \\
4 & 1 \\
1 & 0 \\
0 & 1 \\
[/tex]
[tex]
1 & 3 \\
0 & 1 \\
a & b \\
c & d \\
a & b \\
c & d \\
a & b \\
c & d \\
[/tex]
Thank you very much for the explanation. I admit the A^3 wa a pretty bad question, I was concentrating on the power to 2003; but I did that and now thanks to your help I'll hope to do 2003. The professor did not manage to mention any of these explanations - we don't even have a book for linear but instead notes...
Thanks, I'll give it a try and no, I never seen anything that dealt with the square root of a matrix...
how to do the square of 3×3 matrix?
please reply me with full method
1. What is the process for solving A^3?
The process for solving A^3, or A to the power of 3, involves multiplying A by itself three times. For example, if A is a 2x2 matrix, you would multiply it by itself twice to get the final result.
2. How do you calculate C^2003?
To calculate C^2003, you would first find the eigenvalues and eigenvectors of C. Then, you would raise each eigenvalue to the power of 2003 and multiply it by the corresponding eigenvector. Finally, you would combine these results to get the final answer.
3. What is the significance of f(A)?
f(A) represents the function of A, which means applying a specific mathematical operation to each element of the matrix A. This can be useful in solving certain types of problems, such as finding the inverse of a matrix.
4. How do you calculate e^C?
To calculate e^C, you would first find the eigenvalues and eigenvectors of C. Then, you would raise e to the power of each eigenvalue and multiply it by the corresponding eigenvector. Finally, you would combine these results to get the final answer. This is similar to how you would calculate e^x for a regular numeric value x.
5. Can you take the square root of a matrix A?
Yes, it is possible to take the square root of a matrix A. This process involves finding the eigenvalues and eigenvectors of A and then taking the square root of each eigenvalue. Then, you would multiply the square root of each eigenvalue by its corresponding eigenvector to get the final result.
