Matrix solutions
given the matrix
https://scontent.fhlz2-1.fna.fbcdn....=7f5d6372c263996c6a11969b072d1349&oe=5BF8F2B7
in RREF
we see solution to this system is x1+x2+x3 = 0
in the textbook it says which solutions are spanned by the vectors f1 = (−1, 1, 0) T and f2 = (−1, 0, 1) T
[/B]
I don't really understand how this is the case? Is the only way to see this to find all possible solutions to this system and then make sure each solution is linearly independent ? Or set x1 = 1 (since x1 is the only leading variable) and then clearly the system is only satisfied when (x1, x2, x3) = (1, -1, 0) or (1, 0, -1), but then why in the text book would they set the pivot to -1 and not just 1 ?
Answers and Replies
tnich
1,048
336
given the matrix
in RREF
in the textbook it says which solutions are spanned by the vectors f1 = (−1, 1, 0) T and f2 = (−1, 0, 1) T[/B]
I don't really understand how this is the case? Is the only way to see this to find all possible solutions to this system and then make sure each solution is linearly independent ? Or set x1 = 1 (since x1 is the only leading variable) and then clearly the system is only satisfied when (x1, x2, x3) = (1, -1, 0) or (1, 0, -1), but then why in the text book would they set the pivot to -1 and not just 1 ?[/B]
What problem are you trying to solve? Finding the kernel of the given matrix?
Ray Vickson
Dearly Missed
10,706
1,722
given the matrix
in RREF
(1) Turn off the bold font!
(2) The equation ##x_1+x_2+x_3=0## describes a 2-dimensional plane in 3 dimensions. You can express any vector in the plane as a linear combination of two linearly-independent vectors, so that for any point ##{\bf p} = (x_1,x_2,x_3) ## in the plane we can write ##{\bf p} = c_1 {\bf p}_1 + c_2 {\bf p}_2##. As we vary ##(c_1,c_2)## we sweep out the whole plane.
The solution is merely giving you two possible linearly-independent vectors ##{\bf p}_1## and ##{\bf p}_2## in the plane; there are infinitely many other possible choices.
Likes UOAMCBURGER
FactChecker
2,899
Three variables and one linear constraint should tell you that there is a two-dimensional solution space. The solutions (1,-1,0) and (1,0,-1) are clearly two linearly independent solutions. The problem is "rigged" to make those solutions easy to spot. Any other solution, like (0,1,-1), can be obtained by a linear combination of the two: (0,1,-1) = -1(1,-1,0)+1(1,0,-1).
(Your statement that (1,-1,0) and (1,0,-1) are the only solutions is not correct. They form a basis for the entire space of solutions.)
berkeman
Mentor
62,285
13,041
Related Threads on Matrix solutions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
