Tinman
- 30
Could a field of a certain.type of magnatism effect a giving area of salt water as to.either align or dispurse the water to more freely flow among them or slide between them .like a horizon of water molecules
ok let's say moving through water is like pushing throught a deck of cards and that's why its so slown .. resistance is ther a way or possible way to turn the deck as to slide through the deck instead of aposing itDrakkith said:I'm sorry but I have no idea what you're asking.
essentaly yes and no more to create a pathway through the particles rather than lessen the density of a givin area perhaps even align them to have them all point one direction with a charged surfaced of opposition to be slipped through persayDrakkith said:Oh, your wondering if you can use a magnetic field to reduce the viscosity of water?
... the sonic boom and what design approaches might reduce it. ... most designs engineers are testing are needle-nosed and < yes key is buggy ty. And no wouldn't high intensity beam just shove particles out of the way it the " space key its playing with the. ..Danger said:Is there some malfunction with your " . " key? It seems to pop up randomly.
Anyhow, now that you've explained it better... the only thing that I can think of that might possibly do what you want is an extremely high-intensity ultrasonic beam of some sort. I doubt that even that would be effective, though.
And a jet's "sound bubble popper" is sheer muscle in the form of tremendous engines.
That's exactly what has to be done in order to accomplish what you want.Tinman said:wouldn't high intensity beam just shove particles out of the way
please exuse me building a house is as far as my science goes. i jusr had a few question about faster than sound speed under water wanted to understand the concept on a smaller levelDanger said:That's exactly what has to be done in order to accomplish what you want.
Tinman said:essentaly yes and no more to create a pathway through the particles rather than lessen the density of a givin area perhaps even align them to have them all point one direction with a charged surfaced of opposition to be slipped through persay
Tinman said:yes +and -electical charges can't atoms aranged and charged to have rotating magetic fields each opposite to the next
Tinman said:cant some sort of information be tranferd.throufh.the.alligned electrical charges ? impact ?something??
and water isn't antiferromagnetic liquid?Drakkith said:Then you'd freeze them and you wouldn't have liquid water anymore, but ice.
Tinman said:Yeah. That was my.point I.guess on some minimal scale can salt water be effected with antiferromagnatism if so could it be effected further .
Danger said:Sorry, dude, but if you insist upon trying to take a magnetic approach to it, you're doomed to failure. It's like trying to make a cow run faster by painting her horns green.
I think that you missed the point of my post.Tinman said:Fine a metal cow with a magnet infont of ia hahah.
so its just push them out of the way and tahts it then.hmm seems like there be more tjere than thatDrakkith said:No. Antiferromagnetism doesn't apply to water, it only applies to solid materials where molecules/magnetic grains can align in certain ways. Water is diamagnetic, not antiferromagnetic.
Tinman said:so its just push them out of the way and tahts it then.hmm seems like there be more tjere than that
Matter alignment refers to the arrangement of particles within a substance. This arrangement can affect the physical properties and behavior of the substance.
Magnetism can cause the alignment of charged particles within salt water, creating a magnetic field. This magnetic field can then interact with the Earth's magnetic field, causing changes in the flow of salt water.
One example is the formation of eddies or swirls in salt water due to the interaction of magnetic fields. Another example is the separation of salt and fresh water in estuaries, where the alignment of particles can affect the movement of water.
Yes, scientists are currently researching ways to use magnetic fields to control the flow of salt water for various applications, such as desalination and energy production.
The effects of matter alignment and magnetism on salt water flow can impact the distribution of nutrients, organisms, and pollutants in salt water ecosystems. This can have both positive and negative consequences on the health and balance of these ecosystems.
