Why Matter Can't Spontaneously Turn to Energy
In summary: This creates a very dense object- a black hole- with a very high entropy. This is because the black hole is a very stable equilibrium (state) and as more and more matter falls into it, it just piles on top of itself and the entropy increases.
menergyam
Why can't matter spontaneously turn into energy? What prevents this from happening? Energy is still conserved.
Suppose we consider an atom as a system. The entropy of the system is very low. Now if the atom turned into energy, then the entropy would increase dramatically, is this correct?
Also, I am thinking that the conversion for mass to energy is a reversible process. However, entropy increased, and in order to compact the energy back together again, you would also be decreasing the entropy again back to when it was an atom.
I though that entropy always increases, I learned this from my thermodynamics class. So, if entropy always increases, then why won't matter spontaneously turn into energy?
Thermodynamics states that the general direction of entropy is increasing, though I'm not sure how it would apply to quantum frames.
It's quite diffucult to be able to state that entropy would increase in that case (as Gear300 says) but even if it was plain true, you still have to consider enthalpy, activation energy and kinetics; in chemistry there are many reactions that are entropically favourite but don't happen for those reasons.
?? It can and it does. Whenever Uranium fissions, the total mass of the fission products is less than the mass of the Uranium atom. That lost matter has turned into energy.
First: no one knows exactly what entropy is, any more than we know what mass or time or space really is. Matter is bound together by nuclear (strong and weak) and electromagnetic forces...I don't think anyone knows why theses forces are as they are. As far as I know the lifetime of matter is unknown but longer than that of the universe. One theory is that these forces (and likely gravity) were all "unified" (as a single force) at the origin of the universe and via spontaneous symmetry breaking ended up as apparently distinct forces we observe today.
So the simple answer is that forces holding matter together holds them for a loooooong time...in other words, the binding forces don't seem to decay except for the weak (radioactive) force...but that's not necessarily the most interesting feature underlying your question!
I do have a crude understanding of current thinking about why matter forms in the first place:
Entropy usually increases, but not ALWAYS. It a statistical phenomena not an absolute rule without exception. As far as we know time never runs in reverse, but entropy can reverse locally (decrease) for extended periods. Entropy as often taught in introductory undergraduate classes does not discuss gravitational relationships with entropy and that changes EVERYTHING.
Here is how Brian Greene in FABRIC OF THE COSMOS describes gravity and entropy(Chapter 6):
The overwhelming drive towards disorder (increasing entropy) does not mean that orderly structures like stars and planets...can't form. When gravity matters clumpiness...not uniformity... is the norm...for an initially diffuse gas cloud...the entropy decrease through the formation of orderly clumps is more than compensated by the heat generated as the gas compresses,and, ultimately by the enormous amount of heat and light released when nuclear processes begin to take place.
So except basically for hydrogen and helium, stars form most elements around us...you are made from the stars! and those process "violate" commonly understood entropy increase rules for long periods.
and regarding black holes:
When gravity flexes its muscles to the limit it becomes the most efficient generator of entropy in the know universe
(gravity causes black holes;black holes have maximal entropy.) (Stephen Hawking and Jacob Beckenstein are famous for their work on black holes,entropy and associated information theory.)
A generally interesting and broad based discussion of entropy and the universe can be found at
http://en.wikipedia.org/wiki/Entropy#Entropy_and_cosmology
The role of entropy in cosmology remains a controversial subject. Recent work has cast extensive doubt on the heat death hypothesis and the applicability of any simple thermodynamic model to the universe in general. Although entropy does increase in the model of an expanding universe, the maximum possible entropy rises much more rapidly - thus entropy density is decreasing with time.
You could easily spend a lifetime studying energy,entropy...and information. Entropy can be viewed as a subset of information theory! (Bet that wasn't mentioned either!)
Except for time, my own view is that entropy is likely one of the least understood scientific subjects by most people...and maybe physicsts as well.
This is a little mixed up. Yes, it's not unusual at all for local entropy to decrease; it happens any time a hot object cools down. But it is incredibly unlikely for total entropy to decrease (that is, for a local decrease somewhere not to be compensated by an adjacent increase, as in the case of heat transfer). For a closed system of much more than a few atoms, you'll essentially never see a decrease in total entropy.
Gravity does not change anything. As Greene points out in the quote you provided, any local decrease in entropy is more than offset by radiated heat. The Second Law is secure, even when considering gravity.
Let's consider a simple case. We have a radioactive sodium 22 (Na^22) source, which is a positron emitter. We watch a positron as it stops, and begins its death spiral around an electron. In a nanosecond or two, its gone, and two 511 keV gamma rays are emitted in opposite directions. The two gamma rays quickly convert to heat energy in matter. Here we have complete conversion of mass into energy, but only beause the particle annihilates with its own antiparticle, thus cancelling all conserved quantum numbers (charge, lepton number, spin). But entropy increases. This is an example of the extreme limit of the complete conversion of mass into pure heat energy.
Can you describe how you calculated this? (Or did you infer it from the spontaneous nature of the process?)
So matter does spontaneously turn into energy! What is the reason underlying that entropy increases over time?
1. Why can't matter spontaneously turn into energy?
The law of conservation of energy states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that matter cannot spontaneously turn into energy because it would violate this fundamental law.
2. Can matter ever turn into energy?
Matter can be converted into energy through processes such as nuclear reactions or particle-antiparticle annihilation. However, these processes require a significant amount of energy input and cannot occur spontaneously.
3. How does Einstein's famous equation, E=mc², relate to matter turning into energy?
E=mc² means that energy and matter are interchangeable and can be converted into one another. However, this conversion requires a specific process and cannot occur spontaneously due to the law of conservation of energy.
4. Is it possible for matter to disappear and turn into energy?
No, matter cannot simply disappear and turn into energy. As mentioned before, energy cannot be created or destroyed, only converted from one form to another. The disappearance of matter would violate this law.
5. Can the process of matter turning into energy be reversed?
Yes, the conversion of energy into matter is possible through processes such as pair production or particle collisions. However, this process also requires a specific amount of energy input and cannot occur spontaneously.
  • Astronomy and Astrophysics
  • Other Physics Topics
