Maximize Area of Rectangle w/ x Feet Fencing
  • Thread starter fk378
  • Tags
    Area
In summary, your homework statement is that a total of x feet of fencing is to form 3 sides of a level rectangular yard. However, you are having difficulty understanding what you need to do to solve the problem. You are trying to find the critical points in order to set A'=0. However, you are missing an incorrect term in your calculation.
fk378
367
A total of x feet of fencing is to form 3 sides of a level rectangular yard. What is the maximum possible area of the yard, in terms of x?
So far I have 2 sides of the yard is denoted by y, and one side is denoted by z.
Then, 2y+z=x
We want to maximize the Area=yz
Now, do I substitute one of the variables in the Area equation to get the answer? Then I know I need to differentiate, but with respect to what? I'm confused here.
Then, 2y+z=x
You're on the right track. A=yz=y(substitute what for z?)
Then you will have an equation for A in terms of y (the variable) and x (the constant). Since you can vary y to vary the area A, you will differentiate A with respect to y, and then do what to find the value of y that gives you maximum A?
Ok, so I have
A=yz=y(x-2y)=xy-2y^2
A'=y-4y
We want to find the critical points so set A'=0
A'=y-4y=0
y=4y
...that doesn't make sense...?
fk378 said:
Ok, so I have
A'=y-4y
A'=y-4y=0
y=4y
Your calculation of A' in the 2nd equation has one incorrect term in it. Remember what you are differentiating with respect to.
[tex]\frac{d}{dy} (xy - 2y^2) = ?[/tex]
1. How can I determine the maximum area of a rectangle with a given amount of fencing?
The maximum area of a rectangle with a given amount of fencing can be determined using the formula A = (x/4)^2, where x is the length of the fencing. This formula is derived from the fact that a rectangle has two equal sides and two unequal sides, and the maximum area is achieved when the two unequal sides are equal to half of the total fencing length.
2. Is there a specific shape that will result in the maximum area?
Yes, a square will always result in the maximum area for a given amount of fencing. This is because a square has four equal sides, making it the most efficient shape for maximizing area with a limited amount of fencing.
3. How does the length of the fencing affect the maximum area of the rectangle?
The length of the fencing directly affects the maximum area of the rectangle. The longer the fencing, the larger the maximum area will be. This is because a longer fencing length allows for longer side lengths, which in turn creates a larger area.
4. Can the maximum area be achieved with any dimensions of the rectangle?
No, the maximum area can only be achieved with specific dimensions of the rectangle. As mentioned before, the two unequal sides of the rectangle must be equal to half of the fencing length. This means that the length and width of the rectangle must be equal, resulting in a square.
5. How can I find the length and width of the rectangle to achieve the maximum area?
The length and width of the rectangle can be found by dividing the fencing length by 4, as both sides of the rectangle will be equal to half of the total fencing length. This will result in a square shape, which will have the maximum area for the given amount of fencing.
  • Precalculus Mathematics Homework Help
9K
