Maximum height of a rocket
  • Thread starter 000
A rocket is launched at a planet of 600km radius, 5.29e22 kg mass, and 9.8068 m/s^2 surface gravity such that it reaches a maximum height 'h' with work 'x'. What is the value of 'x'? Ignore air resistance, and gravity is dependent on height.
Unsure of where to start.
None.
Answers and Replies
voko
6,054
391
Kinetic energy.
Potential energy.
Work.
Kinetic energy.
Potential energy.
Work.
Could you clarify?
voko
6,054
391
Do you know how all these are interrelated? Could you apply that relation to your problem?
gneill
Mentor
20,945
2,886
A rocket is launched at a planet of 600km radius, 5.29e22 kg mass, and 9.8068 m/s^2 surface gravity such that it reaches a maximum height 'h' if it undergoes a constant acceleration of 'x' m/s^2. Ignore air resistance, and gravity is dependent on height.
None.
Ask yourself, "at what height will it stop accelerating?" The question statement seems to indicate "never". If it always accelerates, what's the maximum height?
Sorry, there was a mistake in the question. What I meant to say was how much work must be done in order achieve height 'h'.
gneill
Mentor
20,945
2,886
That's quite a departure from the original statement of the problem :uhh:
What do you know about the relationship between work and potential energy?
How does gravitational potential energy relate to the position of the rocket?
The gravitational potential energy is dependent on the square of the height, correct?
gneill
Mentor
20,945
2,886
Nope. There are two important relationships for gravitational potential energy that you should be familiar with. The first is for the potential when the field is assumed to be uniform and constant, such as in the region close to the surface of the Earth (in reality it is thus just a very good approximation). The second is the actual Newton's Law version which does not make an approximation.
1) ##PE = mgh~~~~~~~~## For close to the Earth's surface
2) ##PE = \frac{G M}{r}~~~~~~~~## In general for point masses (or ones that behave so)
The second form must used when the change in radial distance is significant (i.e. gravity depends upon height).
voko
6,054
391
This must be ##PE = -\frac{G M m}{r}##
gneill
Mentor
20,945
2,886
Indeed :smile:
Suggested for: Maximum height of a rocket
  • Last Post
  • Last Post
  • Last Post
  • Last Post
