Maximum Height of Dropped Package in Helicopter Accident: 1279 meters
In summary, the package was dropped from a helicopter traveling upwards at 28 m/s and it reached a maximum height of 1279 meters above the ground.
Lucretius
152
A passenger in a helicopter traveling upwards at 28 m/s accidentally drops a package out the window. If it takes 19 seconds to reach the ground, how high to the nearest meter was the helicopter when the package was dropped?
The answer I got for this is: 1237 (to the nearest meter)
This is not my problem however, the next question is, and it reads:
To the nearest meter what was the maximum height of the package above the ground in the previous problem?
I thought maybe I would use the distance formula again, with x=v0(t)+1/2at^2
The number I get isn't right…the answer is 1279.
Well since the helicopter was traveling upwards, I would say the maximum height would be when the package was dropped. The helicopter was moving at a constant speed, meaning no acceleration. So once the package was released, the only force acting on it was gravity, making it head downward immediately.
That's my reasoning.
Remember that the package was traveling upwards at 28 m/s (this was initial velocity). So when the package is dropped, it still had some upwards motion. I need to figure out the distance covered from v=28m/s to v=0.
Ok. Sorry it's late. Use the kinematic equation you listed in your OP. Just make sure that you include direction, because the initial velocity and the acceleration are in different directions. It seems straightfoward from there.
What numbers would I be plugging in? If I plug in the 28, 19, and 9.8 I just get my first answer: 1237. 1237=28(19)-1/2(9.8)(19^2)
The answer however, is 1279.
Nope. That is wrong. Why you choose t = 19s?
You know the plane is 1237 m above the ground, when the package is dropped.
The package will reach its maximum height when its velocity is 0. Because the package's initial velocity is 28 m / s. And it decelerates to 0 m / s. After that it will start to fall down. So when the package's velocity is 0, it reaches its max height.
How long does it take for the package to decelerate to 0 m / s?
Viet Dao,
Oh, I get it now!
First I use v=v0+at, and find T=~2.9
then I reuse x=28(2.9)-1/2(9.8)(2.9^2). X=39.99999, aka 40. So I get 1277. I guess an error of 2m is acceptable.
1. What is the definition of maximum height?
The maximum height refers to the highest point that an object can reach in a given situation or environment.
2. How is maximum height calculated?
The maximum height can be calculated using the equation H = u2sin2θ/2g, where H is the maximum height, u is the initial velocity, θ is the launch angle, and g is the acceleration due to gravity.
3. What factors affect the maximum height of an object?
The maximum height of an object is affected by the initial velocity, launch angle, air resistance, and the acceleration due to gravity. Other factors such as the shape and mass of the object can also play a role.
4. Can the maximum height of an object be greater than its initial height?
No, the maximum height of an object cannot be greater than its initial height. This is because the object will always fall back down due to the force of gravity. However, the maximum height can be equal to the initial height in certain scenarios.
5. How does air resistance affect the maximum height of an object?
Air resistance can reduce the maximum height of an object by opposing its motion and causing it to slow down. This is why objects with a large surface area, such as parachutes, have a lower maximum height compared to objects with a smaller surface area.
