• Support PF! Buy your school textbooks, materials and every day products Here!
Maximum power on a resistor
  • Thread starter crom1
1. Homework Statement
Find the maximal power on resistor R.
2. Homework Equations
3. The Attempt at a Solution
I used Thevenin theorem. I found that Z_t=5+j10 , and U_t= 10-j10. The maximum power happens in this case when $$R=|Z_t| = 5 \sqrt{5}$$ , and I get that P=6.18, while the answer is P=8.3.
Where did I went wrong?
gneill
Mentor
20,510
2,619
There's hard to tell where you went wrong if you don't show the details of your work.
However, can you show how you found the Thevenin impedance?
57
When I look at it again, I get Z_t=5+j5,but I still get wrong solution. Do you want me to post my full (wrong) solution?
I found 5+j5 (parallel circuit of 10 ohms and j10 ohms)
gneill
Mentor
20,510
2,619
When I look at it again, I get Z_t=5+5i,but I still get wrong solution. Do you want me to post my full (wrong) solution?
Yes, that would be best.
57
So I found thevenin impedance as parallel circuit of 10 ohms and j10 ohms (I can ignore 10 ohms and -j10 ohms since there is voltage source parallel to them).
Point A is to the left of our resistor , and point B to the right.
Bottom line of a circuit has potential equal to 0 (i don't know how to say it in english, hope you understand).
point A has potential 10V. When finding potential of point B, i ignore voltage source of 10V( the on the left). The impedance is parallel circuit of 10+j10 and 10-j10 so Z=10 ohms.
The current is then 1+j. The current going through 10+j10 is exactly 1 A, so the potential of B is j10. Now U_th= 10-j10.
R should be 5 sqrt(2) , the current in thevenin circuit should be I=U_th/(Z_th+R) = 1.083 (effective value) and power is P=I^2R=5.86
gneill
Mentor
20,510
2,619
Your Thevenin impedance and voltage look good, as do the resistance and the magnitude of the current that you found. The first problem I can see is with the very last bit, the calculation of the power, P = I2R. Check that calculation again. Break it down by calculation step if necessary.
57
Thank you, I was putting R=5 this whole time and not 5sqrt(2). Now it's correct.
Related Threads for: Maximum power on a resistor
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
10K
