1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Maximum power transfer
  1. Feb 20, 2014 #1
    Maylis
    a) What value of the load resistor RL will extract the maximum amount of power from the circuit below?
    b) How much power will that be?
    Hint: you need to use both the concepts of Thevenin equivalent circuits and maximum power transfer.
    2. Relevant equations
    3. The attempt at a solution
    I am confused why the ''source voltage'' is the thevenin voltage and not the actual source, or why I have to solve this problem with a thevenin equivalent? Also, is the method correct and did I solve it correctly?
  3. Feb 20, 2014 #2
    rude man
    100% correct.
    You didn't have to solve it using thevenin but it's a good way to do it.
    You never have to use thevenin or norton unless the prof insists on it. But again it's often good to do so, as in this case. The alternative is 3 equations in 3 unknknowns with some pretty horrible expressions. With thevenin you're taking advantage of the fact that max power happens when the load R = source R, for a given source R.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Maximum power transfer
  1. Maximum power transfer (Replies: 2)
  2. Maximum power transfer (Replies: 5)
  3. Maximum power transfer (Replies: 3)
Loading...
