Maximum stress
  • Thread starter qwerty0123
trying yo figure this out:
the graph of stress concentration factor K for flat bars with a circular hole geometries are shown in the diagram link below. a load of 50kN is applied to the plate. the width of the plate b=100mm with a thickness of t=10mm
find the maximum stress for the following:
1. plate without hole
2. plate with hole (diameter 50mm)
3. how much is SCF? well k=nominal stress / maximum stress but im not sure how to get the maximum stress, is it s chart or the graph below?
http://imageshack.us/photo/my-images/15/scfvk.jpg/
this is what i have done so:
stress=P/A
p=50X10^3
A=(b-d)h = 50mm x 10mm = 500mmsquared = 0.0005m squared??
so nominal stress is = 50x10^3/0.0005 = 6000???
Answers and Replies
ive found the stress for the plate without the hole to be:
P/A
P/bt= 50000/0.001
50MPa
cant do the second bit though
cant find the correct area either
PhanthomJay
507
Pick out the stress concentration factor based on the given dimensions and solve for the max stress near the hole using your formula.
how do i do that?
PhanthomJay
507
how do i do that?
Stress concentration factors are derived from the Theory of Elasticity. In this example, the stress concentration factor is plotted on the y axis and the d/b ratio is plotted on the x axis. Find the correct value of d/b on the x axis, and move up vertically until you hit the curve (hint, the SCF is somewhere in between 3 and 2.5). Once you determine the SCF, then use the formula given in the chart to calculate the max stress near the hole. Note that the reference (nominal) stress is calculated based on the cross section area of the plate minus the cross section area of the hole. You would get different SCF factors if you use the stress on the plate without the hole as your reference stress. I assume the graph given is given correctly.
i've got d/b to be 0.5 since d=50 and b=100 d/b=50/100 = 0.5
using the graph i get 2.2?
PhanthomJay
507
Oh yeah that's about right I gave a bad hint because I wasn't looking at the graph and going from my incorrect memory of it from an earlier viewing, Sorry. So now that the SCF is 2.2, calculate the max stress near the hole using the formula given on the chart.
haha thats ok.....ive managed to get the maximum stress as 110MPa
since 2.2x50MPa = 110 000 000
thats part 2 done but what about part 3 the SCF?
PhanthomJay
507
But the SCF factor is based on the nominal stress using the net section area at the hole, not the gross section area. Your answer is not correct.
You just told me that the SCF is 2.2!
Related Threads on Maximum stress
  • Last Post
10K
  • Last Post
9K
  • Last Post
  • Last Post
20K
  • Last Post
  • Last Post
25K
