Maxwell 3D
  • Thread starter Jdo300
Hello All,
I have Maxwell 3D on my computer and I want to use it to do some 3D magnetic torqure analysis on some magnet designs that I am working on. I have created a model that I would like to simulate in AutoCAD and I want to transfer it to Maxewell to do the analysis. But I am not sure how to use the software and I was wondering if anyone here knows how to work with it. If not, does anyone know of any good tutorial sites for it?
Thanks,
Jason O
Answers and Replies
PerennialII
i recently picked up maxwell 3d. and also have a model in autocad 2004 (originally modelled in 3dsmax 7) that i'd like to analyze and see field lines for. have u figured out how to do this yet? maxwell comes with a built in translation program, but it wont let you go from autocad to maxwell 3d, just 2d, so when you import it into maxwell 3d its flattened out.
PerennialII
I'm still pretty much stuck in same gear ... got interested about it again and should reinstall Maxwell3D to see whether could get ahead with it. Wonder whether some other software / model format could be used as an intermediary to make the transition possible ... got to list what both ends support and see if can find something.
Gokul43201
Staff Emeritus
I've done some electromagnetic modeling on ANSYS 8.0 where you can import objects from ProE.
I think someone in our group may be using Maxwell. I'll ask around.
Hi, I did figure out how to get the CAD 3D Models into Maxwell, you just have to highlight everything in the drawing and use the export command to save it as a n ACIS file (*.sat) which Maxwell's drawing program can import. Then from there you can do the simulations.
As it turns out, I did figure out how to do some simple simulations but does anyone know anything about setting up macros to run the simulations automatically?? I read on their site that it is possible but I'm not sure where to go or what to do.
Thanks,
Jason O
thanks loads :)
Hi, I am trying to import a 3D model into Maxwell. Have you tried to do this. If so, how exactly did you do that. Do I go to Draw and file/import. My model consists of many regions having different electrical(material) properties. How can I assign different material properties to these different regions although my model was generated outside of Maxwell (A stack of MRI images were used to reconstruct a 3D head model, it was saved in a DXF format). Any help is appreciated
Noha
Noha
Well, first you need to resave the file as a .sat (ACIS) file, to import into Maxwell, then create a new project and inside the 3D Modeler, select File/Import/3D Modeler-ACIS file in the menu. If you have it saved as the right version it should load fine. Then save the model and goto the Setup Materials button to assign the properties for all the objects.
God Bless,
Jason O
Transient sover in Maxwell 3D
Hi all,
I have been using the magnetostatic solver in Maxwell 3D to solve for the conduction induced by a voltage source. The solver gives the electric potential distribution within the ohmic conduction medium.
I want to expand this and instead of a static source have a time-varying voltage source. As far as I have understood, I have to use the transient solver of Maxwell 3D and define a stranded voltage source as a coil terminal. Is this correct? Furthermore, the solver solves only for the current density J and not for the electric potential. Does anybody know how I can get such a solution from the transient solver in Maxwell 3D (i.e. the distribution of the electric potential in a volume conducting medium generated by a time-varying source)?
Thank you in advance,
Stamatis
Hi All,
I´ve been trying Maxwell 3d V11 for a while, and got stuck into a rather unusual difficulty.
If one model a permanent magnet and try to move or rotate the geometry, the poles orientation won´t follow the transformation. The poles look like to be referenced to the active CS where the geometry was created. Does any one know how to overcome this problem ?
Dear Sir,
I am a somewhat old learner of ansoft maxwell. But the latest version 12 any tutorial is available online, please tell me
Hi all,
I am using Maxwell 3d v12 for simulating permanent magnet generator. The magnets are magnetized through thickness. I can't define it to Maxwell. How can i define the magnetization direction?
Thank you in adavnce
sanjida
someone has been able to work with winding editor maxwell 3d
Hello,
It seems most people here are talking about the magneto-static solver has anybody used the eddy current solver? I am having a hard time understanding how to set excitations? I am trying to model an alternating magnetic field in a solenoid coil. I have simply included the coil and tried to set the a current density through it. It seems it cannot accept the coil by itself but need current density terminals. Is it possible to set an AC voltage source for the coil without specifying a current density functions?
Thank you.
Anybody?
Let me rephrase my question as I realize it was probably vague and that what I was asking about was not what I really wanted. I am trying to set up a current through a coil in the eddy current solver. I have tried assigning a current to the faces of the ends of the coil but it appears the solver assumes the excitation is only at the ends. (i.e. the ends do not seem to be on the conduction path. How do I get the software to realize current is flowing into the coil?
Thank you very much.
PS If this is still vague please let me know
PPS If I have not been getting replies because this is not in the proper thread please let me know as I am new.
Jedi1234,
Are you still looking for help with this?
-Pat
No I figured it out, thanks!
Hi there,
When setting up a transient solver problem in Maxwell 3D, the following error occurred when running the simulation:
Could not find the half_face for a mapping vertex
Does anyone know what this means? When I use the magnetostatic solver the simulation runs fine.
Thank you in advance for answering!
Greetings Arno
Hello any one can help me to find tutoriles about electromagnetic generator using ansys or ansoft software .. thanks
Hello Noha,
I use Solid Works to draw every element of my model, and after that I make assembly of these elements. When assembly is ready, I save it like ".step'' and inport in Maxwell 3D. In this case I can define different material for every one element ot assembly.
Is there an easy way to import a spreadsheet of data points into Maxwell 3D?
hello frens,
I am trying to design a double layered concentrated winding switched reluctance motor in maxwell 3d. Can anyone who is acquainted with this topic please tell me how to give the double layered coil in maxwell, because i am not being able to find the option to give double layer. Or is it possible to draw such coils in maxwell itself?? If yes, then what type of coils can be drawn, helix or spiral? thank you.
regards
Firdausa
Boundary Conditions in 3D
Hello,
We are trying to model magnetic field of a permanent magnet(AlNiCo5) in 3D. We have drawn a cylinder and assigned the material to it. We have constructed the background region around it. The main problem is that we dont know which boundary conditions to give.
Please help us.
Thank you
Related Threads on Maxwell 3D
  • Last Post
16K
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
