MC (multiple choice) question about total internal reflection
In summary,The necessary conditions for the light ray to travel along the core of the fiber are that n1 > n2 and angle i should be greater than a certain value.
cainko
There is an optical fiber.A light ray enter it at i°.Total internal reflection occur at X.
What are the necessary conditions for the light ray to travel along the core of the fiber?
(I have canceled B and D already.)
A.n1>n2 and angle i should be greater than a certain value.
C.n1>n2 and angle i should be less than a certain value.
sinθa/sinθg=1/n; sinc=1/n;n1/n2=v1/v2
For t.i.r. θ>c
r=90°-θ
r<90°-c
But I don't understand how I can determine i is greater than or less than c(certain value) because i and r are not the same?
Thank you so much!:)
cainko
(Sorry for my bad drawing)
Welcome to the PF.
What's an MC?
Why do you say that n1 > n2? You might review your notes or textbook.
In order for total internal reflection to occur at the boundary between n1 and n2, does the angle of incidence θ (in your drawing) need to be greater than the critical angle or less than the critical angle?
What happens to the angle θ if the angle i is increased?
Welcome to the PF.
What's an MC?
MC is multiple choice question:)
I am so sorry!:( I draw the figure wrongly!
for t.i.r. light must travel from low speed to high sped,for light ray:larger n --> smaller n ==>n1>n2
θ will increase when angle i increased??
sini/sinr = n ; sini increase-->sinr decrease==>θ=90°-r, r decrease θ increase?
thx so much!
OK, no problem.
sin(i)/sin(r) = n implies that sin(i) = n sin(r). So, if sin(i) increases what happens to sin(r)?
TSny said:
OK, no problem.sin(i)/sin(r) = n implies that sin(i) = n sin(r). So, if sin(i) increases what happens to sin(r)?
decreases?
The equation sin(i) = n sin(r) says that sin(i) and sin(r) are directly proportional to one another. If one increases so does the other.
Oh, so r<90°-c ---> i is also<90°-c ?? so i is less than certain value?
No. You are right that the condition r < 90 - c will produce total internal reflection at X.
But that doesn't imply that the angle i must also be less than 90 - c. You are very close to the answer.
Let rc = 90 - c. So, when r = rc, θ = c. You correctly stated that whenever r is less than rc, you will get total internal reflection at X.
When r = rc, the angle i will have some value which we can call ic. How could you find ic if you knew rc? Does ic equal rc?
What is the condition on angle i such that you get total internal reflection at X?
as i increase when r increase, to make r< rc , i should be<ic too?
Yes.
1. What is total internal reflection?
Total internal reflection occurs when a light ray traveling through a denser medium reaches the boundary of a less dense medium at an angle greater than the critical angle, causing the light to be completely reflected back into the denser medium.
2. What is the critical angle in total internal reflection?
The critical angle is the angle of incidence at which total internal reflection occurs. It is determined by the refractive indices of the two mediums involved in the reflection.
3. What are some real-life applications of total internal reflection?
Total internal reflection is used in various optical devices such as prisms, fiber optic cables, and binoculars. It is also used in some medical imaging techniques and in underwater communication systems.
4. Can total internal reflection occur in all mediums?
No, total internal reflection can only occur when light travels from a denser medium to a less dense medium. It cannot occur if the light travels from a less dense medium to a denser medium.
5. How does the angle of incidence affect total internal reflection?
The angle of incidence must be greater than the critical angle for total internal reflection to occur. If the angle of incidence is less than the critical angle, refraction will occur instead of total internal reflection.
