Mean and STDev
  • Thread starter noreturn2
Member has been warned not to remove the template.
Mind mean and STDev of number of quarters someone has on them at one time
0 - 87%
1 - 8%
2 - 3%
3- 1%
4 - 1%
The first time I did this I assumed a population but she said that was wrong and not what she was looking for.
Here was my new attempt:
x^2f(x)=
0(.87)
1(.08)
4(.03)
9(.01)
16(.01)
sum= .45
so: .45-(.2)^2=.6403
I want to do E[x^2]-[E[x]]^2=stdev
Answers and Replies
FactChecker
2,893
I guess I am missing something. Where are those multipliers (0, 1, 4, 9, 16) coming from? What formula are you using?
Oh, I guess I see. You have a variable with values (0, 1, 2, 3, 4) with probabilities 0.87, 0.08, 0.03, 0.01, 0.01, respectively. You should have made that clear in your problem statement.
In that case, you should be more careful about your calculations. I get 0.45-(0.21)^2 = 0.4059
I forgot to add in part of the problem statement. I've added that.
x^2f(x)
vela
Staff Emeritus
Education Advisor
15,434
2,051
$$0.45-0.2^2 = 0.45-0.04 = 0.41$$ So don't write that it's equal to 0.6403. The equal sign doesn't mean "the next step in my calculation gives me..." Trust me, when you write something like that, it annoys your teacher at best and probably drives her crazy. Instead, you could say ##0.45-0.2^2 = 0.45-0.04 = 0.41## for the first step and then ##\sigma = \sqrt{0.41}=0.6043##.
(As @FactChecker noted, you should recheck your calculations.)
Again, this isn't true. The lefthand side is equal to the variance, not the standard deviation.
It appears you basically know what you're doing, but you need to be more careful in writing stuff down to demonstrate that to others (like the person who is going to grade your test).
Likes FactChecker
So my answer of .64043 was correct?
vela
Staff Emeritus
Education Advisor
15,434
2,051
Close, but as @FactChecker noted, you need to check your calculations.
So what is throwing me off is I think my calculation of the mean is incorrect. Because more people has 0 quarters then say 2 quarters, the the mean should theoretically be less then 2 correct?
vela
Staff Emeritus
Education Advisor
15,434
2,051
Right. Since the vast majority of people had no quarters, you'd expect the mean to be relatively close to 0.
So would it be .45/100%= .0045, which seems also wrong but makes sense. Since the .45 is the number of quarters in the "system" sorta say, and then we accounted for 100% of the population.
FactChecker
2,893
Yes. But your calculated mean of 0.2 (should be more accurate 0.21) is much smaller than 2. Why do you doubt that answer for the mean?
FactChecker
2,893
I don't understand where you are getting the 0.45 number. In any case, dividing by 100% makes no sense to me.
I suggest that you stick with the established formulas and be more careful with them. You essentially got the right answer the first time, but you presented it carelessly and it was not possible (for me) to follow what you were doing.
Ok so here is what I have let me know if this looks better
Mean: .21
87(0)+8(1)+3(2)+1(4)+1(3)=21/100
STDev:
E[x^2]-[E[x]]^2
.45-(.21)^2=.4059
sqrt(.4059)
STDEVA: .637
FactChecker
2,893
Much better. Some improvements could be: Show the calculation of E[x^2] that gave you .45, label the variance, and use the same name STDev (not STDEVA).
Ray Vickson
Dearly Missed
10,706
1,722
Mean: .21
STDev:
E[x^2]-[E[x]]^2
.45-(.21)^2=.4059
sqrt(.4059)
STDEVA: .637
Never write 87(0)+8(1)+3(2)+1(4)+1(3)=21/100; in fact, 87(0)+8(1)+3(2)+1(4)+1(3)=21, period. I think what you want to do is note that 0.87(0)+0.08(1) + 0.03(2) + 0.01(4) + 001(3) = 0.21, so that is what you should write. Alternatively, you can say in words that 87(0)+8(1)+3(2)+1(4)+1(3)=21 is 100 times the mean, so you need to divide the result by 100 to get the mean.
Related Threads on Mean and STDev
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
