Mean Value Property in partial differential equations
Your Name]In summary, we can use the maximum principle for harmonic functions to prove that for any r satisfying 0<r<1, there must exist a point (x1,x2) in S such that u(x1,x2)>=1, given that g(x1,x2)>1 for any (x1,x2) in ∂S. This is because the maximum value of a harmonic function inside a domain is attained on the boundary of the domain, and since u=g on the boundary of the ball S, the maximum value of u inside S must also be greater than 1.
ajax2000
S is a ball of radius 1 in R^2;
Δu=0 in S
u=g in ∂S, g(x1,x2)>1 for any (x1,x2) in ∂S. Show that for any r satisfying 0<r<1 there is a point (x1,x2) in S such that u(x1, x2) >=1.
using mean value formula: ∫u(y)dy=1/Vr^n(∫u(y)dy)
g(x1,x2)=(1/2π)∫g dS, g(x1,x2)>1 on the boundary
(1/2π)∫0 to 2π g dS=1/2π(2π*g^2/2), 2π cancels out, leaving g(x1,x2)=g^2/2>1
u=g on the boundary so g(x1,x2)=u(x1,x2)>1.
I don't think I did this right, I might have to use u(0,0), any hints will be appreciated
Your attempt at a solution is a good start, but there are a few things that need to be clarified and corrected. First, the mean value formula you used is not applicable in this case, as it is only valid for functions that are harmonic in the entire domain. In this problem, the function u is only harmonic inside the ball S, not in the entire space R^2.
To solve this problem, we can use the maximum principle for harmonic functions. This principle states that the maximum value of a harmonic function inside a domain is always attained on the boundary of the domain. Since u=g on the boundary of the ball S, we know that the maximum value of u inside S is equal to the maximum value of g on the boundary.
Now, we are given that g(x1,x2)>1 for any (x1,x2) in ∂S. This means that the maximum value of g on the boundary is greater than 1. Therefore, the maximum value of u inside S must also be greater than 1. This proves that for any r satisfying 0<r<1, there must exist a point (x1,x2) in S such that u(x1,x2)>=1.
I hope this helps clarify the solution to this problem. Good luck with your studies!
FAQ: Mean Value Property in partial differential equations
What is the Mean Value Property in partial differential equations?
The Mean Value Property in partial differential equations states that the average value of a function over a region is equal to the value of the function at the center of the region. This property is often used to solve boundary value problems in which the solution is known at the boundaries of a region.
How is the Mean Value Property used to solve partial differential equations?
The Mean Value Property is used to simplify the solution of partial differential equations by reducing the problem to a simpler one-dimensional problem. This allows for easier computation of the solution and can help in finding boundary values and other important features of the solution.
What are the assumptions behind the Mean Value Property?
The Mean Value Property assumes that the function is continuous and sufficiently smooth within the region of interest. It also assumes that the region is simply connected, meaning that it does not have any holes or disconnected parts.
Can the Mean Value Property be applied to non-linear partial differential equations?
Yes, the Mean Value Property can be applied to non-linear partial differential equations. However, the solution may not always be unique and additional techniques may be needed to find a specific solution.
How does the Mean Value Property relate to physical systems?
The Mean Value Property has many applications in physics and engineering, as it can be used to solve problems involving heat transfer, fluid flow, and other physical phenomena. It is also related to the concept of energy conservation, as the average value of a function can be interpreted as the total energy of a system.
